"G35xS" Brake and rotor size?
Old Nov 4, 2019 | 07:45 PM
Carlos Flores's Avatar
G35xS
I'm needing to replace these on my xS model and cannot find anywhere what the right sizes are. Can someone help please?
Thanks.
Old Nov 4, 2019 | 08:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check out these guys.
https://www.r1concepts.com/
As long as you are looking for rotors for an AWD 2007-2008 sedan there should only be ONE option for rotors. Coupes had two different rotor sizes available for 2007-2008 depending on year and package.
Old Nov 5, 2019 | 05:03 PM
Hall Stevenson's Avatar
I have a "spec sheet" for the sedan the AWD model wasn't even available with the Sport package. I'm not sure this sheet is 100% accurate though..... I've seen some "xS" models on the road but maybe they were 2-door, not 4-door. If it's correct, as you say, there's only (1) rotor setup (320mm front, 307mm rear).
Old Nov 5, 2019 | 05:05 PM
Measure them. They'll either be 320/307mm (front and rear) or 330mm (same size, front and rear).
Old Nov 5, 2019 | 05:07 PM
G35xS
Solved!
I think you are right. 320mm front, 307mm rear is what the last reply on this forum post stated. Thanks everyone.
https://g35driver.com/forums/v36-bra...do-i-have.html
Old Nov 5, 2019 | 05:40 PM
cleric670's Avatar
BANNED!!!
I think the sport package was available, I'm pretty sure it was the only way to get the paddle shifters on the AWD models. Not sure what else it included but it was probably just tires/wheels because of the unique suspension components on the AWD.
Old Nov 5, 2019 | 05:52 PM
G35xS
08 g35xS
XS model includes all available packages by default (premium and nav) plus 18in OEM rims, sport seats, paddle shifters, and I think some minor exterior styling? Mine has a factory spoiler although I've seen xS models without it.
I read somewhere it was released in late 2008 and was the last addition to the G35 line up.
It's been a joy to drive but this finding parts thing has been a bit of a headache.
Old Nov 7, 2019 | 09:24 PM
The spec sheet I have has no reference to an "XS" trim so if it was released later, that would make sense.
For the majority of parts, you can stick to finding "X" trim parts, I think. The larger brakes on the "S" trim were also linked to different size tires in the front and rear which they skipped on the AWD models so you just want "X" brake components, I'd think. Suspension parts ? Good luck !
Old Nov 8, 2019 | 10:46 AM
I actually have the 20+ page brochure for the G35 that comes with new cars and it refers to the "Sport Package AWD". Details are:
  • Solid magnesium paddle shifters
  • Split 7-spoke 18" aluminum wheels (w A/S tires)
  • Unique front fascia and side sills
  • Front sport seats w/ thigh extension....
  • Unique sport steering wheel stitching
  • Aluminum pedals
Available on G35X AWD
avion
Nov 21, 2017 08:17 AM
g35SedanSC
Jan 13, 2014 06:03 PM
srt4evah
Mar 21, 2013 03:34 PM
infini_
Jun 26, 2007 04:07 AM
Railgunner
Dec 13, 2006 12:32 PM
