DIY: M45s Shift Knob
Old Jan 14, 2008 | 04:17 PM
07G35Socal's Avatar
Originally Posted by G35s-Dude
Great man, would be greater if you can write about the lenght and how much did you cut off the metal shaft and the white plastic piece so people (me) don't mess things up and buy new assembly .
It was a lot of trial for me, better to cut long than short. I will take it back off and do some measurements before I re-lube it up. A side note, ALL SHIFTER PARTS ARE METAL! (except the white piece).
The front and back slits are pretty easy to eye, they are very close to the original bottom side notches. I took my dremel with a cutoff wheel and went down the center of the 2 original slits, then pushed it left to right to widen the slit close to the original width. Better to go a little thinner and test fit as you go. Make sure to watch your depth with the cutoff wheel, you don't want to be cutting into the inside lever.
For the outside lever shortening I took a wooden skewer (flat side) and stuck it down the shift ***** on the side so it hits the first level (you will see when you look down inside there is a ridge that the original outside lever bumps into, make sure you don't stick it down the center where the inner shift lever goes). I marked the clip notches for both ***** on the skewer. Should be just under 3/4 inch.
The white piece and inner lever were the parts I had to grind and fit, grind more and fit.... I started by marking and taking off a little less than what I did from the outside lever and went from there.
I will do some measuring of the final product and update.
Old Jan 14, 2008 | 08:24 PM
07G35Socal's Avatar
Measurements
Here are some pics with my tape, autofocus is currently not working on my D40x so it was a little tough.
Take your time, do lots of test fitting, better to keep it a little long and slowly grind away until it's just right. Also take a look at how the shifter functions before you go cutting away at it.
Unfortunately I hate to say this, but in this day and age you have to. "Do this at your own risk, I will not be held liable if you go cut happy and ruin your shift lever!!!"
All measurements are my best guess based off of the pictures and my installation. Look carefully at the pictures and also do some of the stuff in my above post until you feel comfortable before cutting stuff.
1 tick mark before 3/8 inch for the inside lever.
~3/4 inch white nub (I recomend cutting the bottom clip off first and then fit the top round portion)
To me it looks like ~3/4 inch from the factory clip slots to the cut outer lever (A little over ~5/8 inch if you stick the tape's teeth into the slot)
Old Jan 14, 2008 | 08:26 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Very nice, looks 100X better than stock.
Old Jan 15, 2008 | 04:52 AM
G35s-Q8's Avatar
Great, but since i'm the type of people that tend to ruin things instead of making them right, i'll just do the swap for the ****, who knows if i might put the original **** back in the futur .
Old Jan 15, 2008 | 05:46 AM
B L U E S L A T E's Avatar
Honda Accord
Do you think I can shortend the OEM ****? I like to have some options.
Old Jan 15, 2008 | 12:09 PM
07G35Socal's Avatar
Originally Posted by Fast07GSdn
Do you think I can shortened the OEM ****? I like to have some options.
From what I saw when I pulled the **** apart modifying the **** to sit lower will not be an option regardless if it is the stock or the M45. The way the button works and lack of extra material to remove to make it sit lower would not make it possible. If you want to play around, pull you **** off and then pop the button out (take a very small flat head, butter knife whatever and use it to pop out the button from the side) take a look at how it functions and the inside of the **** itself.
Old Jan 16, 2008 | 09:13 PM
CtK's Avatar
CtK
Very Nice!!
Can we still order this from Jason??
Old Jan 17, 2008 | 05:30 PM
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by CtK
Very Nice!!
I don't see why not, but just sent him a PM to make sure.
Old Jan 17, 2008 | 06:29 PM
Jason@Riverside's Avatar
Yes they are still available for driver members!
Y50 Sport ***** (Black w/ White Stitching) (Just got a new batch instock! (on back order everywhere else).
$92.50 Shipped out side of California
$99.31 Shipped IN California
Out side of the US PM me.
Black or Willow finishes are more. PM for details!
Old Jan 18, 2008 | 11:39 AM
O HELLA OEM's Avatar
^^will this fit an o4 G coupe auto if so very interested
Old Jan 18, 2008 | 11:46 AM
shoeless's Avatar
Does anyone have an the '07+ G35 **** in black that they are no longer using? Mine is nicked up beyond repair.
Old Jan 18, 2008 | 12:50 PM
The M **** will fit any G with a shift boot.
Old Jan 19, 2008 | 10:16 AM
g35sedan5at's Avatar
shoeless, i currently have a black g **** that i might get rid of for this M sport **** but i havent madeup my mind yet. ill let you know. the sport **** costs 92 from jason so ill let my stock one go for lemme say 50, i dont know,lol. not really trying to make money, just get back some i spend on the M ****.
Old Jan 19, 2008 | 12:31 PM
for what its worth... new OEM 2007-2008 G35 Sedan Auto **** = $153.72 MSRP. My forum price would be $115.30 plus shipping...
Old Jan 19, 2008 | 11:22 PM
  #30
Wow, that's amazing Jason. I can't believe it's more expensive. Now that I have the M45s shift ****, the OEM shift **** for the G shouldn't be worth anymore than half the price of the M **** IMO. I am sure you would agree there is a big difference in quality between the two.
