DIY: OE G37 sedan trunk spoiler install
Old Jan 29, 2009 | 06:50 PM
  #46
Phalanx's Avatar
oh man, my bad. I looked at the picture carefully and I figured out that I was wrong. It was the reflection of the Infiniti emblem on the trunk lip that makes it looks like a camera on it. LOL
Old Jan 29, 2009 | 09:00 PM
  #47
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by AesonVirus
Hey Ian... yeah, I see the double edge and actually like that design.
My concern is the bottom edge where it touches the trunk. The very front leading edge.
There appears to be gaps between the spoiler and the trunk lid.
Is it less noticable in person?
Ohhhh...
Yes it is absolutely less noticeable in person.
I can't quite figure that pic out, especial right at the end;
it must be shadows or something
It actually sits very nicely along the trunk.
Old Jan 29, 2009 | 09:01 PM
  #48
InTgr8r's Avatar
yeah... sorry it's not a camera trim
Old Jan 29, 2009 | 09:07 PM
  #49
InTgr8r's Avatar
Wayne, are you planning on drilling holes in the trunk lid on the end locations or are you going to try and only use double sided tape on the ends?
I'm waiting for someone to mount one, using only holes drilled behind the chrome finish plate location to see if fitment is acceptable.
I don't mind drilling holes behind the finish plate, but there's something about drilling holes on the trunk lid that has me upset. I know it's a permanent install, but I can get past it mentally.
Scott, I really can't see tape pulling the outer ends down tight enough onto the lid.
I know what you mean about drilling.....
The way I look at it is;
I'd rather do a good careful job myself than have someone else slap it on.
Old Jan 29, 2009 | 10:20 PM
  #50
AesonVirus's Avatar
Maybe I'll wait until I see one in person.
If I love it, I'll do it.
Problem is, I'm not drilling holes for anything I'm not 100% sold on.
Old Jan 29, 2009 | 10:30 PM
  #51
InTgr8r's Avatar
Can't disagree with that...
Old Jan 29, 2009 | 10:44 PM
  #52
GEE35FX's Avatar
Scott, these are the Push Clips that go in the end holes. You can see where they will slide onto the spoiler then when you install it and push down on the spoiler ends, then these clips snap into the drilled holes. There isalso some double sided tape on the spoiler. Note the rubber sealing gasket to seal the hole. All holes through the trunk have sealing washers to seal them
Here is what is included with the Spoiler
Old Feb 9, 2009 | 12:07 AM
  #53
HYSPAN's Avatar
What's the OEM part number for the spoiler?
Old Feb 9, 2009 | 09:25 AM
  #54
InTgr8r's Avatar
^sorry IDK...
It was ordered through Rick@Riverside here.
..there are two different spoilers;
one with just 1 hole for the button
& the other with 2 holes, button & cam.
Old Feb 10, 2009 | 11:17 AM
  #55
HYSPAN's Avatar
On the installation instructions it lists part numbers.(GEE35X post^) Im looking for the non-camera model, but if only camera model is know its a start.
Old Feb 10, 2009 | 11:20 AM
  #56
InTgr8r's Avatar
ahhhh sorry, yes I see.
I may still have that sheet... I'll check later tonight.
Old Feb 11, 2009 | 01:24 PM
  #57
HYSPAN's Avatar
is the part number K6030-JK62A?
Old Feb 11, 2009 | 02:10 PM
  #58
InTgr8r's Avatar
sorry man... got in real late last night.
I'll try to remember tonight.
Old Jun 7, 2010 | 08:56 PM
  #59
J2S2M's Avatar
Sorry for diggin up an old thread..
but anyone know if you can install the spoiler w/o drilling the 2 holes on the sides? It already comes with 3M double sided tape to hold down the spoiler, plus there are other mounting points where the chrome piece used to sit in order to screw down the spoiler.
I just don't think it is absolutely necessary to drill the extra holes on the sides. Can anyone confirm this?
Old Jun 7, 2010 | 11:01 PM
  #60
E-Ticket Ride's Avatar
I believe the consensus was that the extra holes were needed as the sides would pop up/rise if they weren't used. Also, many said that the spoiler didn't sit flush, again necessitating the use of the side holes.
