DIY: Wheel spacer vibration fix
Jun 16, 2009 | 10:15 PM
This DIY is a result of this thread;
spacers resulting in wheel vibration
The Problem...
one cause of the problem….
The OE wheel has an exceptionally deep hub chamfer.
This means that there is very little for the spacer hub to seat onto.
2nd cause of the problem….
The depth of the spacer hub is shallow.
This is not a problem for most wheels,
but when combined with the OE wheel above, the hub is too short.
In this pic you can see that the hub when in place in the spacer,
sits back past the spacer surface.
This is done so that there is no chance of the hub extending too far out
& preventing the wheel from mating flush on the spacer.
….However in our case, it just adds to the lack of depth issue.
With the hub removed from the spacer,
I was able to engage the hub into the wheel bore ONLY if 100% pushed into the wheel.
Reply 0
The Fix...
The basic idea is to keep the spacer hub extended as far as possible w/o interfering with the wheel.
It would be possible to bond the hub in place in the spacer with epoxy, JB weld etc.
Since that meant getting the extension just right by eye,
I decided against it.
I went with a crush ring in behind the hub that would hold the hub extended,
but crush into place when the wheel was tightened.
That way it would self level.
The detail pics……
I was able to remove the hub from the spacer w/o taking the spacer off.
I used anti-seize when I installed though, so YMMV
I made the crush ring from a piece of #10 copper wire (solid, not stranded)
I used the hub to shape it. (sorry for crappy pic)
crush ring sized to hub bore.
Insert crush ring, then re-insert hub into spacer.
Hub re-inserted…
Note it sits out from spacer face.
It will crush back into place when the wheel is tightened
& that's it.
My vibration is completely gone
Reply 0
Jun 16, 2009 | 10:24 PM
*clap clap clap clap clap clap....*
Your the best Ian
Reply 0
Jun 16, 2009 | 10:26 PM
might I suggest using the macro setting on your camera when taking close up shots so it doesnt blur.... :P
Reply 0
Jun 16, 2009 | 10:27 PM
Quote: might I suggest using the macro setting on your camera when taking close up shots so it doesnt blur.... :P
...shaky hand, I was thinking about my 1st ICB.
Reply 0
Jun 16, 2009 | 10:32 PM
Great fix Ian .
The V2 spacer with your mod is the way to go.
Reply 0
Jun 16, 2009 | 10:34 PM
Will this issue be present in the V1 version?
Reply 0
Jun 16, 2009 | 10:38 PM
JMO but I would never use a V1 type of spacer with extended lugs.
...but yes, likely the same issue. (assumption that hub is the same design)
Reply 0
Jun 16, 2009 | 10:41 PM
^^+1 on that, I do not like the thought of using the longer studs with the V1 spacer, I would feel much safer with the V2 Spacer. I just don't like the thought of using the longer studs with the stress that is involved. You would not believe how much a stud will stretch ( I have used a piece of equipment at the Nuclear Plant called a Biach Stud tensioner that torques studs by stretching them so you can tighten the nuts to the proper torque values and it is amazing the amount of stretch involved)
Reply 0
Jun 16, 2009 | 10:53 PM
Interesting.. thanks for the info guys.
I would have never known these things. All the while, I thought v1 was safer.. :S
Reply 0
Jun 16, 2009 | 11:05 PM
The moral of the story is... AFTERMARKET WHEELS!
Reply 0
Jun 17, 2009 | 08:03 AM
...changing the studs is a biatch as well.
New ones have to be pressed into the axle hub,
which means taking everything apart.
Reply 0
Jun 17, 2009 | 08:05 AM
Quote: The moral of the story is... AFTERMARKET WHEELS!
& the moral of the moral of the story is......
get AFTERMARKET WHEELS with the right offset = no spacers
Reply 0
Jun 17, 2009 | 08:11 AM
how about hub centric spacers?
Reply 0
Jun 17, 2009 | 08:42 AM
The V2s are hub centric as well, just a 2pc design.
It all depends on how long the hub extension is.
Is that a single machined piece?
The hub looks longer than the V2
Are those the 25mm H&Rs?
...again with V2, it's only an issue because of the OE wheel.
Reply 0
