DIY: Clean your throttle bodies
Rating: Thread Rating: 2 votes, 4.50 average.
Old Feb 19, 2010 | 03:15 PM
  #31
Q8y_drifter's Avatar
Glover997, there's no special coating on/in the TB. It's just a cast piece of metal with a valve that is connected to the TB with a shaft and two screws. That's it. You can use whatever you want as long as it's rubber/plastic safe and has lubricating properties.
Old Feb 19, 2010 | 04:07 PM
  #32
Glover997's Avatar
ok Q8y . . thanks a lot !
this is the most important DIY i come a cross . .
thats exactly what i need actually .
Old Feb 19, 2010 | 04:47 PM
  #33
No problem. This is probably the best "maintenance" DIY I've done to my car since I bought it. I'm so happy the whole rough idle issue is now gone and more importantly I know that it was the TB's.
Old Feb 19, 2010 | 05:15 PM
  #34
G35s-Q8's Avatar
Time to go to bed because you have to wake up early tomorrow, give me a call and we'll go to the dyno, i might be sleeping, so a wake up call would be nice, i've set my alarm at 9am, and i've called a friend of mine to come with his C6 to dyno test it.
Old Feb 19, 2010 | 05:39 PM
  #35
The list just keeps growing lol.
2 G's, 335i, STi, C6 and another car I forgot who haha.
Old Feb 23, 2010 | 12:26 PM
  #36
kregg's Avatar
Thanks for the DIY. I did this on my wife's '03 Murano (another 3.5l variant) which always stalled when started after warm up. Now if the engine is warm it starts and RPM stay rock solid, no sudden drop or stall like it used to do.
Thanks Again!!
Old Feb 23, 2010 | 01:10 PM
  #37
np...
Old Mar 14, 2010 | 11:21 PM
  #38
firozu's Avatar
would this fix the problem im having with my car when it idles... the idle drops and comes baq up quite a few times... i thought it was the fact that the small hose that leads from teh intake to some part in the engine was too small and i should cut a new one for it...
Old Mar 14, 2010 | 11:24 PM
  #39
That's the exact issue I had and it went away after cleaning the TB's.
https://g35driver.com/forums/v36-eng...-rpm-drop.html
Old Mar 14, 2010 | 11:40 PM
  #40
MixturePinoy's Avatar
This is a must.. I do this every 3rd oil change, I also clean my MAF sensor and clean and oil my intake filter. I recommend these products for upkeep:
Old Mar 14, 2010 | 11:54 PM
  #41
I use both of those CRC products. Good stuff!
Old Mar 15, 2010 | 03:00 AM
  #42
kool_yaar's Avatar
^ same here CRC is great and reliable for TB, iv never tried the MAF cleaner though i think ill pick this up and clean em along with my filters.
Old Mar 15, 2010 | 11:57 PM
  #43
firozu's Avatar
i have used that last product recently definitly gonna do the first and will let you guys know if my idle dropping goes away
Old Mar 16, 2010 | 06:32 AM
  #44
G35s-Q8's Avatar
It well go away, just keep us updated.
Old Mar 16, 2010 | 05:38 PM
  #45
kool_yaar's Avatar
Just performed this DIY today and man WHAT A DIFFERENCE! my rpm is now rock solid with NO surges whatsoever! Thanks Q8y_drifter this has to be one of the best DIY!
Anyone experiencing idle rpm surges where car seems like it will die, do this DIY and you will be here thanking Q8y it is SUPER EASY just requires some time. The TB were much more dirty than expected, i will try to snap a pic of the MF towel i used and you will be shocked to see all the dirt i had @ ~46k.
BTW does anyone know the torque specs for TB hex screws? maybe i missed this but i think i might have overtightened it a bit.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
