DIY: Clean your throttle bodies
Rating: Thread Rating: 2 votes, 4.50 average.
Old Jan 30, 2010 | 09:10 PM
CalsonicVQ's Avatar
+1 on TB cleaning, but according to my dealership, there's a special coating on the TB so be extremely careful of using too much TB cleaner or scrubbing too hard. Anyway, my fluctuating idle and "hard to start" problems went away after they cleaned the TBs.
They even took a before and after pic.
After: When viewed straight on, you can see a perfect, thin ring of light when the TB plate is closed.
Before: The ring of light (and airflow) was blocked off in many sections by the nasty deposits.
Old Feb 15, 2010 | 07:03 AM
G35s-Q8's Avatar
nice, i should clean mine soon, i need to clean my air filters, those Injen are damn hard to reach.
Btw did you notice any difference in throttle response? or you didn't bother at all?
Old Feb 15, 2010 | 07:45 AM
j 4 lD's Avatar
Where exactly is the harness connector? I have a 03 Sedan BTW.
Old Feb 15, 2010 | 08:21 AM
mikek46's Avatar
Originally Posted by docaam
good write...time to do mine now..I just corssed 40k miles
Just crossed 40k last night on my '06 as well. I'm wondering if I should clean mine when it gets warmer....from these pics I dug up a few weeks ago, it looks like could use a cleaning, yet my idle is rock solid :shrug:
Old Feb 15, 2010 | 09:26 AM
Q8y_drifter's Avatar
G35s-Dude, throttle response is definitely better. It's not faster, just much smoother.
The harness is located towards the dash on the TB. You can kinda see it on a couple of those pics.
Old Feb 16, 2010 | 08:30 AM
Bahg35's Avatar
My TB got dirty again. I Installed my Gen3 and the second or third day, and i got a rough idle etc.
I want to clean them but i dont have the guts to open em up. I dont want to F(*& it up.
Old Feb 16, 2010 | 08:59 AM
It's really simple. I cleaned the TB on my dad's 02 pathfinder with the old spring loaded throttle lever style TB. Now that's really messed up lol
Old Feb 16, 2010 | 10:35 AM
5u30five's Avatar
since the tar and carbon deposit is due to the crankcase vent, can we just disconnect the hose and vent it in the atmosphere or a catch can. i remember doing this on my celica and civic back in the days. will it work the same?
Old Feb 16, 2010 | 10:40 AM
JMZ_blkobsidian's Avatar
Thank you!
That was a great DIY and I will try it soon.
BTW, my G is 3 years old with 15,500 miles. Is it worth doing the TB cleaning at this point?
Old Feb 16, 2010 | 11:12 AM
You definitely can. I haven't checked all the lines and hoses from the block to the intake but i'm assuming there are no sensors that would otherwise be triggered from doing so. Or you can simply stick an inline filter and still route it to the intake like this>
Old Feb 18, 2010 | 03:32 PM
G35s-Q8's Avatar
Cleaning TB is a must if you're living in the GCC, i cleaned mine today, and wow i really felt a difference, the car feels more smoother, better throttle response, rpm is pretty smooth, you really should clean them, you won't believe how dirty they are when i opened them.
I used WD-40, it cleans and lubricate, use the nosel to spray the shaft so that all the dirt inside the shaft that you can't reach well come out with the nosel spray pressure.
After i finished i turned the car on and the rpm jumped to 2500 and didn't drop down until i pressed the gas pedel, the it stuck at 1500 rpm, so i let the car to reach normal operating tempreture and i floored it for 2 runs, turn the car off, let it cool down, i started the car again, and the rpm was normal.
Old Feb 18, 2010 | 05:09 PM
Glover997's Avatar
great !
but will (WD-40) do harm on the TB's speciall coating ?
WD-40 is kinda strong chemical , so it's better to use a special TB cleaner, i believe .
what do u think ?!
second . . should i disconnect the negative terminal before i do the cleaning ?
thank you Q8 for the important/useful topic
Old Feb 19, 2010 | 12:20 AM
docaam's Avatar
im planning to do it this weekend...mine mut be really dirty as i drive just on motorways usually..bought a TB cleaner lets see if it will work
Old Feb 19, 2010 | 07:08 AM
G35s-Q8's Avatar
Originally Posted by Glover997
great !
what do u think ?!
What special coating? we've been using fuel, WD-40 and carburetor cleaner age's ago, nothing happened to any of the TB we cleaned, as long as you use something that would lubericate the shaft you should be fine.
Go ahead guys, clean your TB and tell how much dirt and sludge you found in there, i was shocked for the amount of dirt i found after removing the TB, i've never seen anything like it before, and BTW it can be done without removing the TB, you can use a towel soaked in whatever clean you want to use and push the flap with your finger and clean it, don't worry about anything, i didn't d/c the battery, i didn't remove any cable or hose, and i pushed the flap wide open with my finger and cleaned it.
Old Feb 19, 2010 | 07:12 AM
  #30
Glover997's Avatar
aw ok . . i'll try to do that without removing the same .
thnQ
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
