DIY: Clean your throttle bodies
Rating: Thread Rating: 2 votes, 4.50 average.
Old May 4, 2012 | 04:26 PM
  #436
richard0ne's Avatar
Haha.. at idle and when I step on the gas the RPM feels a bit sluggish. I would really love to do this but as of right now, I can't afford to have any issues with the idle if things went array.
After all, last weekend I just changed the belt, camshaft sensor Bank 2, spark plugs, rebuild the valve cover with new grommets, fuel damper, clutch interlock switch.
Had white smoke from the new plugs (oil in tube) with rough idling, perform all three resets perfectly to get my idling perfect at 600-625.
I'm seriously thinking about doing this though lol
Or maybe not
04 G35 with 87k miles, I'm sure she is filthy
Old May 7, 2012 | 02:35 PM
  #437
NYT's Avatar
NYT
OK, so I tried this TB clean and am having some idle issue too. I also installed a Z-tube and cleaned my MAF and air filter, so it’s conceivable to me the computer is having some issues adjusting with its new found air flow.
It’s drivable, but a little erratic. I have the SES light, idle is a little high (~1k) and deceleration is a little sluggish (1 sec delay). I tried disconnecting the battery (negative terminal) for 30min, but same results.
Question is: Do I jump into trying the Idle Relearn or give it a few more days (including WOT runs) to see if it adjusts itself?
Old May 7, 2012 | 02:47 PM
  #438
richard0ne's Avatar
Do the idle relearn and throttle body ASAP.
Old May 8, 2012 | 12:22 AM
  #439
MaDMaXX's Avatar
Yeah, always do this.
Old Jun 2, 2012 | 02:18 PM
  #440
B L U E S L A T E's Avatar
Honda Accord
My procrastinating *** had been lagging to do this for 20k miles. smh
I'm gonna get my *** up and finally do this today. Crossing fingers on not fcking up my butterfly valves and MAF. haha
Old Jun 12, 2012 | 11:12 AM
  #441
bluedevils95's Avatar
How long does this take? Planning on doing this this month since my Idle is jumping around.
Old Jun 13, 2012 | 07:34 PM
  #442
pandesal28's Avatar
So my car idles like previous posts (at idle, with car warmed up, it has a rev cycle from 1k to 2k)
tried:
1. relearn process (i believe i did it right since the ses light started to blink)
2. disconnected battery
3. drive it for a few days
4. check for loose connections
i am pretty much running out of ways to fix it.
I did everything the diy stated, but i came out with a different result. Any ideas?
Old Jun 13, 2012 | 08:12 PM
  #443
kool_yaar's Avatar
^ unfortunately you will just have to keep redoing the relearn procedure until u get it exactly right, even a second missed here or there and you have to redo it, as i have said many times throughout this thread doing the relearn procedure exactly as needed is not that easy the first few times. just try a few more times.
Old Jun 13, 2012 | 08:28 PM
  #444
MaDMaXX's Avatar
Yeah, just be wary of when you do get the relearn right, that it might not remember it
Old Jun 13, 2012 | 09:02 PM
  #445
kool_yaar's Avatar
^ ?? iv done this a lot of times on many 1st and 2nd gen G's and fx and once i get the relearn right thats the end of it, i havent had to redo the procedure after getting it right once...
Old Jun 13, 2012 | 09:24 PM
  #446
MaDMaXX's Avatar
There are a few of use that cannot get the learned idle to save, it's fine until you turn the engine off and on again
Old Jun 13, 2012 | 09:51 PM
  #447
I take it some of you guys disconnect the whole thing?
Old Jun 13, 2012 | 11:23 PM
  #448
pandesal28's Avatar
i get the mil light to blink, so im doing it right? Right when it goes solid i let go, and start the car as quick as i can.
thanks for responding to me btw, kinda soothes my stress lol
Old Jun 14, 2012 | 02:17 PM
  #449
kool_yaar's Avatar
if you read through the previous 15-25 pages you will see that many people thought they had done it right but were having problems upon retrying it again and again while making sure they time everything perfectly they sorted out the problem.
You dont need to panic as this is a common issue and everyone get s it fixed sooner or later, you just have to re-read the relearn procedure thats listed several times in this thread and redo it until you get it right.
If you still cant then just post in your regional forum or here and hopefully someone in your area who knows the procedure pretty well can meet up with you and help you do this, some people have done this in the past with success
Old Jun 14, 2012 | 02:30 PM
  #450
ppl are having problems i might just take it in and get it done now. All you do is take it apart w/out discounting the harness and put everything back together once you finish cleaning. Why is everyone having problems?
My idle is jumping from 900 to 500 all the time, and i was hoping to do this this week or the next
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
