Headgasket or waterpump failure.
Old Dec 21, 2022 | 05:58 PM
Bigboss727's Avatar
Infinity G35 VQ35HR
Hey guys, thanks for being awesome.
picked up a 08 G35 130 k
was dumping Coolant into the Oil.
milkshake city,
Was certain I would be heading into check out the block and pistons. And change the gaskets etc.
upon getting the timing cover off, found a totally shot water pump....
thing was over heating and eating coolant.
coolant looks clean, oil is a milkshake...
Just looking for a little advice as to continuing to take the back cover etc off. This water pump was a problem, was eating itself....
I feel like I’m going deeper then I have too, looking for a little experience with a total water pump failure.
I have good compression, did not run a leak down as I was sure to be going all the way.. too late.
Old Dec 21, 2022 | 07:38 PM
Joenavy85's Avatar
G35x Base
I changed my water pump out last year, not sure what you mean by taking off the back cover, as I only pulled the front cover. While you're in there replace the chain guides and tensioner, and if you're feeling adventurous get at the oil gallery gaskets as well.
Old Dec 21, 2022 | 08:14 PM
Bigboss727's Avatar
Infinity G35 VQ35HR
I am going to continue on to replace the
headgasket unless I get some better advice and someone thinks the waterpump was what needed changing,
little nervous... heading forward
Rear cover then cams all have to come out,
thanks for the reply.
Old Dec 21, 2022 | 09:09 PM
Urbanengineer's Avatar
Can’t read your first message for some reason, but why would you pull the valves??? Leave the buckets in, pull head bolts, and pull off heads.
Old Dec 21, 2022 | 09:12 PM
I was able to quote it and see it.
your water pump corroded, froze up, and overheated the engine. Damn. Sorry to hear that. Definitely recommend replacing the rear timing cover gallery gaskets while in there. If you don’t, it’ll poke it’s ugly head out in a few thousand miles.
I would definitely replace the head gaskets and pray your block will still mate well to the heads. You may consider getting the heads planed as they may have warped from overheating.
Old Dec 21, 2022 | 09:23 PM
Bigboss727's Avatar
Infinity G35 VQ35HR
Thanks Urban, will do just that.
Exactly what I needed to hear.
take care of those water pumps yall.
Old Dec 24, 2022 | 01:05 AM
Bigboss727's Avatar
Infinity G35 VQ35HR
hey thanks for enlightening me on the paper gaskets, will also be replacing those while I’m in.
thanks Joe.
happy holidays.
gcoupe_toronto
Canada
Feb 10, 2011 12:36 AM
andiz35
Mar 4, 2008 01:30 AM
