Clutch noise on high rpm shift
Old Dec 11, 2007 | 09:56 AM
aozmaxed's Avatar
My G35S is just past its 2K miles. Does anyone notice the 'zing' sound as you work the clutch, let's say anything above 4K rpm? Is it just my footwork that's a bit off on the timing? Did I not find the sweet spot yet?
Old Dec 12, 2007 | 01:41 PM
chilibowl's Avatar
If its not affecting drivability, id say its normal. G's make an assortment of noises/sounds, most claimed by the Stealership to be "Normal".
Old Dec 13, 2007 | 05:55 AM
CoppellStereo's Avatar
you could be experience what i am, when i accelerate fast in first and second, then i'm at about 45ish i go to shift to 5th while the RPMS are dropping, with the clutch pedal fully pressed in, the gears still grind, anyone know whats that about?
Old Dec 15, 2007 | 10:15 PM
aozmaxed's Avatar
Well, this is the ONLY area I'm not happy with. Everything to do with the clutch and tranny sounds are just too coarse. Can't get it more smoother and quieter. Even my seven yr old Max SE has quieter clutch operation.
Next step will be switch to synthetic fluid in the 6MT.
Old Jan 17, 2008 | 12:52 AM
aozmaxed's Avatar
Need more inputs on how to quiet the clutch and tranny. Too whiny, but anything I could do? Would syn fluid help? I'm at just over 2K miles.
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
