exhaust tips
Old Jan 23, 2008 | 08:49 PM
ckp's Avatar
ckp
exhaust tips
So i am just going to install some exhaust tips to make it look nicer from the back. i dont care about the performance/sound of an actual exhaust system, so the question I have for you guys is...what size is the inlet for the 2007+g35s sedan exhaust's? If anyone knows i'd appreciate it, it would make purchasing my exhaust tip much easier! Also is this a simple mod? Just screw the old one off, and screw the new tips on? Thanks in advance!
CP
Old Jan 23, 2008 | 09:39 PM
_evilMonkey_'s Avatar
not sure if our stock tip comes off which i dont think it does, just buy muffler with tip design u like and replace it with stock ones. u'll have different sound and look.
Old Jan 23, 2008 | 09:40 PM
ckp's Avatar
ckp
that's the thing, i dont want the different sound. dont like the attention of the sound.
Old Jan 23, 2008 | 09:41 PM
ckp's Avatar
ckp
i'll look and see if its possible to take off the stock tips.
Old Jan 23, 2008 | 10:54 PM
CoppellStereo's Avatar
in my opinion, i dont think any other tips would look as well as the ones already on it
Old Feb 6, 2008 | 08:29 AM
baileyt35's Avatar
One of mine came off when I back into a cement slab(with a backup camera). Not sure you want to remove them that way though I love the oval shaped tips, VERY NICE
Old Feb 6, 2008 | 09:56 AM
G35Now!'s Avatar
Moderation-free
CP
A guy on the forum did exactly that - think his ID is Sedanman07, or something like that. He removed the stock tips (think he actually cut them off), and replaced them with bolt-on tips he liked better.
Old Feb 6, 2008 | 09:59 AM
terrycs's Avatar
There is a chrome shroud over the stock exhaust exit. You'd have to cut the end of the miffler off and weld something back onto the remaining pipe section. It should be very apparent on your car.
Old Feb 7, 2008 | 06:34 AM
pedropedro's Avatar
just some info. I backed into a rock, bent the tip. The dealer installed a new tip. I know they did not weld a thing.
Old Feb 7, 2008 | 07:31 AM
Garnet Canuck's Avatar
Traveling Administrator
Yep, good memory. Here is his original thread about the exhaust tips, but unfortunately the pictures no longer work. On a side note, he hasn't posted since October........too bad, I enjoyed his posts here in the 07+ Sedan section.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
