Crank/Underdrive pulley
Old Jun 25, 2008 | 10:37 AM
suby01's Avatar
i was wondering how hard it would be installing the pulley on the 07 sedan?
any info or pictures would be appreciated.
http://www.stillen.com/product.asp?i...odel=G35%204DR
Old Jun 25, 2008 | 11:01 AM
LiquidGx's Avatar
Not real hard I would imagine, just a matter of having a big enough wrench/breaker bar.
Anyone know if our stock crank pullies are dampened/harmonic balancers?
Old Jun 25, 2008 | 02:16 PM
silverG2007's Avatar
Stock diameter though? What's the point? You aren't going to gain that much power through the weight reduction.
I've always stayed away from pullies on my cars. They seem to always have issues and only gain a few hp (even the smaller than stock ones).
Old Jun 25, 2008 | 02:21 PM
LiquidGx's Avatar
Right. The only benefit is lower spinning weight i.e. lightweight flywheel.
Old Jun 26, 2008 | 12:51 PM
alti35's Avatar
Nobody has installed it yet???
Old Jun 26, 2008 | 10:42 PM
Probably not.
So far for this car, it looks like you could throw about $4000 in aftermarket mods on it, and only net about 20hp.
There aren't enough people here with deep wallets and low expectations yet.
Old Dec 25, 2008 | 02:48 AM
suby01's Avatar
first off a couple pics.. as you can see compared to the mag this thing is huge, weight difference is stock is a little over 8 lbs and this one is 2 lbs so im losing 6lbs off of the turning ratio.
and now the quick review...didnt do the dyno after the install because per UR that results will show after 5-7 days or 200miles where maximum hp will be gained.
IT WAS A BISHH AND A HALF TO INSTALL nut was on so hard on, it says only 30 ft of tq thats less than a wheel nut. that was not the case. took like 2 hours and three broken tools until it was loose.
it was snowy out and still icy so i never got on it until i put about 50 miles on the car and just now coming home highway ramp was all salted and dried out. stopped vdc off shifted first. slip light hasnt been blinking this bad since idn. almost went sideways.
second pulled and third was like with boost. i dont know i still need clean stretchway and for it to breakin but so far. super power gains.
Old Dec 25, 2008 | 05:11 AM
G35Robby's Avatar
That looks sick bro.
I hope you can open her up when you get the chance.
Is there any other difference that you noticed?
Old Dec 25, 2008 | 05:34 AM
1SlowSedan's Avatar
Robby go to sleep
Old Dec 25, 2008 | 05:43 AM
Csquared's Avatar
Robby never sleeps hahahaha
Old Dec 25, 2008 | 05:44 AM
1SlowSedan's Avatar
Haha you can say that again. He was post whoring on Socalg till 5 am yesterday!
Old Dec 25, 2008 | 05:46 AM
titan13qb's Avatar
fo real everytime i dont sleep robby is on and im starting to assume that he is a vampire/or some creature that only comes out at night...damn i need to work on what i say...i just sounded like a dumas
Old Dec 25, 2008 | 05:54 AM
Csquared's Avatar
LOL hahahaha maybe he needs no sleep.
Old Dec 25, 2008 | 06:28 AM
Q8y_drifter's Avatar
losing 6lb's of rotational mass is pretty good!
Old Dec 25, 2008 | 11:26 AM
EnviedG35's Avatar
The bolt was so tight because its supposed to be a one time use bolt. It has a thread lock on it to prevent it from backing out from all the vibration of the engine. It doesnt require much torque to because once it heats up the sealant melts and acts like super glue within the threads. Once the bolt, or nut is taken off though, this sealant isnt effective. Ive done a few GM engines and all the crank bolts were this way. Ive never taken apart a VQ, but i would assume it would be the same principle since its a crank bolt.
