My morning at . GTM!
Old Nov 19, 2008 | 06:15 PM
  #556
jsmonet's Avatar
the only thing a larger housing will do for you in terms of boost creep prevention is give you a larger internal WG port.
if there is less resistance going through the impeller as there is exiting via the WG port, you get creep. that's why people are saying you should just have the housings ported and have a bigger flapper fitted.
for that kind of money i would have expected external gates, but that's neither here nor there. Adding them now would be kind of a pain in the ***.
terry: are you on test pipes now?
Old Nov 19, 2008 | 06:29 PM
  #557
terrycs's Avatar
Yes, the internal wastegates are restrictive at high RPM. I believe they want the larger port in the bigger housing. External gates would be a fix for sure, but they want to try this change first to keep the cost of the kit down. Plus, there may be a space issue down below with the larger bell housing on an automatic transmission.
Yes, there are TP on the car now.
Old Dec 3, 2008 | 03:23 PM
  #558
silver g's Avatar
So did you get it back yet?
Old Dec 3, 2008 | 03:34 PM
  #559
terrycs's Avatar
Not yet, but very soon. Boost creep and smoke all fixed but now I have problem with mod "creep". I'm having a Blitz boost controller put in while it's there. I don't think I need 470 WHp every day.
Old Dec 3, 2008 | 03:56 PM
  #560
ANMVQ's Avatar
And why not.. Happy for you man all si fixed and gettig back soon.. I know you can't wait to drive it.
Old Dec 3, 2008 | 04:06 PM
  #561
Q8y_drifter's Avatar
i don't know much about turbos, but can you use the controller to lower the boost all the way down? i mean to the point where the turbos wouldn't force any air in?
Old Dec 3, 2008 | 04:31 PM
  #562
silver g's Avatar
Thats good to hear Terry!! Glad to see its almost all finished. Whats wrong with 470whp everyday? Hahahaha!!
Old Dec 3, 2008 | 05:59 PM
  #563
bfranks's Avatar
Some days you need more
Glad to hear it's almost done. You have more patience then most of us.
Old Dec 3, 2008 | 06:00 PM
  #564
Hotdawwgman's Avatar
Cant wait to see it!
Old Dec 3, 2008 | 09:46 PM
  #565
AlterZgo's Avatar
No. Most boost controllers let you lower the boost to a base level and that is the lowest it goes. You cannot get to 0 psi of boost.
Of course, if you want to drive w/o boost, just don't floor it and you can easily stay at or below 0 psi.
Old Dec 4, 2008 | 09:21 AM
  #566
IvoryPearl07G's Avatar
sweet!! yea just lower the boost so its around 350whp, then during crunch time bring her back up to 450+!!! you will see ALOT of benefits in the long run.
Old Dec 4, 2008 | 11:32 AM
  #567
kool_yaar's Avatar
Nice, good to hear that they finally fixed all the problems and now its you who's delaying driving your car....
Old Dec 5, 2008 | 01:46 PM
  #568
Calpolytlo's Avatar
I still can't get over your HP figures thats rediculous. . .oh and I'm super happy that you're getting your car back soon!
I have the same questions about your boost controller. . .what kind of range are we talkin here?
Old Dec 5, 2008 | 02:06 PM
  #569
terrycs's Avatar
The Blitz EBC has 4 set points that starts to operate at what the wastegate actuators are set up for. The actuators on my car are set for 5 PSI which is the LOWEST boost. The other 3 settings on the EBC will be set progressively higher... up to probably 9-10 psi which should be around 470 WHp from previous dyno testing. GTM's dyno should be back up by today so they can take actual measurements.
I was told to pick my car up tomorrow AM!
Old Dec 5, 2008 | 03:00 PM
  #570
B L U E S L A T E's Avatar
Honda Accord
Yay! I'm so excited!
DOMO
