Stock + intake dyno only
Old Aug 13, 2008 | 01:42 AM
KulG35's Avatar
Question Stock + intake dyno only
This is starting to drive me a little crazy, sounds like everyone is saying that every intake for our car makes it loose power. If you have, please post dyno of car that is STOCK with only the intake. Interested in Stillen, Injen, and JWT. JWT is the only one I haven't heard get blasted. Injen seems next best but a pain to install, and stillen... well mine is for sale.
If you have PLEASE post dyno's!
Old Aug 13, 2008 | 01:52 AM
titan13qb's Avatar
I just got my car dynoed for the second time today...about two months ago I dynoed my car once I put on my fujita intakes...I got 246 rwhp...today I dynoed it because i wanted to see if I gained any power from my HKS Mufflers...turns out I only got 2whp...but I'm pretty sure that I gained a little bit of power from stock to intake...
Old Aug 13, 2008 | 02:42 AM
dofu's Avatar
20 Year Member
Keep in mind that the temps and humidity 2 months ago was different and you probably would have been getting higher numbers since it was probably cooler then. Temperature differences alone can affect the reading by up to, but not limited to 5hp, depending on which dyno you were on. And of course dyno to dyno will get you different results too. The best way to get consistent numbers is to dyno the same day before the temperature changes too much.
Old Aug 13, 2008 | 03:12 AM
Mongkey007's Avatar
titan.. where do you get ur car dyno'd at?
Old Aug 13, 2008 | 09:11 AM
kmuniz78's Avatar
Check here for mine: https://g35driver.com/forums/tech-07...a-intakes.html
I have since put my stock intakes back on. You are more than welcome to buy my Fujita's though!
Old Aug 13, 2008 | 11:26 AM
suby01's Avatar
ok so this is aggrivating me. i will do a dyno same day same time i have the stillen longtube and HFC so ill do it with the intake and then take it off and see if there is a power loss or gain.
Old Aug 13, 2008 | 01:36 PM
KulG35's Avatar
Awesome... I have the stillen long tube and thing def seemed better when I took it off. I have HFC and exhaust as well...let me know how it goes. Will the stock or any under perform because the ECU hasn't adjusted to the airflow?
Old Aug 13, 2008 | 02:03 PM
Ggirl35's Avatar
i've never heard of it losing power. i have the stillen cai with the ztube. i feel power. but im suppose to be getting it dynoed within the next 2 weeks, so ill let u know. stillen is dyno proven. btw anyone does anyone think an 06 g35 coupe would get into high 13's with just an intake?
Old Aug 13, 2008 | 03:08 PM
silverG2007's Avatar
I blame the internet, but people seem to get obsessed over dyno numbers.
In reality, a dyno is best as a tuning tool.
On the same day, with the same car, a dyno can vary by 5hp or more. Different days, different dynos? Could be a 30+hp difference. You really can't compare them looking for 5 and 10hp gains.
Real testing for power should be done at the drag strip. You'll be able to tell from your time slips and trap speeds whether or not your car gained power (and is faster).
But, again, you can't look for 5 and 10hp gains at the drag strip either. You can't even FEEL anything less than a 10hp gain anyways. So IMO, if you can't feel a difference, don't waste $$ on it. Get an intake or exhaust for the sound and look.
Old Aug 13, 2008 | 03:21 PM
ugaexploder's Avatar
+1
I also hate how everyone thinks dynojet numbers are "real"...i feel like dynojets add like 30hp as compared to other dynamometers
Old Aug 13, 2008 | 03:53 PM
titan13qb's Avatar
VENGS DYNO PERFORMANCE at 46th and memorial...you can also go to humble performance but its more expensive...
Old Aug 13, 2008 | 03:55 PM
titan13qb's Avatar
no...should be around mid 14s
Old Aug 13, 2008 | 05:31 PM
KulG35's Avatar
I agree, but when I had a stillen on mine and took it off...there was a noticeable difference in torque! hp, ehh couldn't tell. I got the Stillen for looks and not gains...but def not for a loss in torque!
Old Aug 14, 2008 | 06:34 PM
I'm with you here. This is my daily driver, I definitely wouldn't give up low end tq (what you use all the time) for high end hp.
Old Aug 14, 2008 | 08:02 PM
KulG35's Avatar
exactly what I notice... high end was good, but low end tq more useless to me
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Daniel k.
Nov 3, 2015 09:52 AM
RA081024
Sep 7, 2015 01:29 AM
Ray Feta
Aug 13, 2015 11:40 PM
