Fumoto valve
Old Aug 20, 2008 | 08:14 PM
georgesa's Avatar
Fumoto valve
I am planning to install the Fumoto valve on the G35x. I am debating getting either the "nipple" version versus the "non-nipple" one.
Has anyone installed the N version? How's the clearance?
Old Aug 20, 2008 | 09:12 PM
mishmosh's Avatar
Get the nipple version. Putting a hose on there makes changing oil much less messy.
Old Oct 29, 2008 | 02:18 PM
Ahujadaddy's Avatar
*bump* any update on this? How did the valve workout, you liking it?
Does the nipple version COME WITH the rubber hose or w/e it is?
i blv the size for us is the F103 (F103N for nipple version), right?
Old Oct 29, 2008 | 03:43 PM
2008G35XSinMD's Avatar
The same day I left the dealership I ordered the fumoto valve with the nipple. At 1,500 miles I changed my oil and it was a cinch. I didnt get dirty at all.
I recommend it without any hesitation. The nipple is certainly worth the extra small expense.
Old Oct 29, 2008 | 03:53 PM
Ahujadaddy's Avatar
The splash sheild we have covering the oil change area def makes me feel easier about getting this. Will give it a shot.
Old Oct 29, 2008 | 03:56 PM
georgesa's Avatar
Yep, I purchased the F103n version. If you do, use the YM5 discount code for 10% off. No hose included. You can get this from Home Depot.
I received the valve, but I'm waiting for my next oil change to install it. It seems that even with the nipple, it would still be safe from being hit by rocks, snow, etc...
Old Oct 29, 2008 | 03:57 PM
g4s's Avatar
g4s
I purchased both versions. I wish I would've gone the nippless route for both.
1) I used a plastic tube the first time around and it was more time consuming putting it on, taking it off and cleaning it after. (You can buy yards of this stuff at any hardware store for pennies)
2) I have not used the tube since. Don't need it and it's not messy w/out.
3) Oil flows out much faster with the nippleless version resulting in a faster oil change.
Bottomline: Fumoto valve is a damn good invention. Just say no to nipples.
Old Oct 29, 2008 | 04:17 PM
What is there to clean?
The used oil goes directly into an old quart of oil container. Once 4/5 are filled up your done. Dispose of the hose correctly and there is no other mess. Take your oil to Advance Auto Parts (In MD area) and they get rid of the oil for free.
As per the claim that nippless drain faster, I don’t believe that for a second. I had the nippleless version on my Jeep Wrangler and the nipple version on my civic. No difference in speed of oil coming out. I even installed both on different people’s civics and I NEVER saw any difference in the speed oil comes out. The orifices are the same size.
Old Oct 29, 2008 | 04:27 PM
LOW2000's Avatar
Any clearance issues with the nippled version? Wife has the car and it hasn't had its first oil change so I have yet to get under the car.
Old Oct 29, 2008 | 04:28 PM
express705's Avatar
you should wait for my EPIC group buy.
Old Oct 29, 2008 | 04:31 PM
None. You have to unscrew the 3 screws on the plastic undercover to even see it. It doesnt lower your clearance at all.
Old Oct 30, 2008 | 06:48 PM
mishmosh's Avatar
Yeah, I've owned the nippless and nipple valves and greatly prefer the one with the nipple. I never clean the hose I use to drain it to the pan--it's a dedicated hose for that purpose! I also have not idea which drains faster--they both drain fast enough!
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
johnadlertech
Sep 6, 2015 12:45 PM
