Berk HFC's!! =)
im getting codes from mine too fromt he stillens bank 1 and bank 2 i talked to several people all that is that its sensing like the air isnt clean w.e. im still looking for a solution i however refuse to take it to the dealer all they will tell me is that its my fault and charge me 70$+ for labor to find that out.
Originally Posted by ugaexploder
^^, get the Fast Intentions High-Flow Cats...you won't be dealing with any of that crap, plug and play boom
Originally Posted by markk132
for the 78th time, the codes i am getting are not from the sensors in the HFC, but from the sensors in the header. the sensor was damaged because of the extreme force it took to unbolt my stock converters. the Berk HFC are plug and play, even my mechanic said how easy the job was once my old converters were out..
If you, or your mechanic, damage parts of your car when removing it to install other stuff, that's not covered under the OEM warranty.
Even if the sensor wasn't damaged during removal, it's likely they have a strong argument to deny your warranty claim. As long as you have those aftermarket HFCs on the car, Infiniti Corporate will have no problem backing the dealer if the dealer denies your warranty claim.
took the car to infiniti this morning, told them i had the HFC installed 2-3 months ago, and that the CEL recently came on because of the sensor in the header. they confirmed that it was in fact the sensor in the header, so they replaced it free of charge under warranty
.......so now i'm just enjoying the intoxicating new sound my exhaust makes
u wont pass the smog test, but if magnaflow makes hfc for us...then those will pass but for nnow...u wont pass smog...unless u know anyone that can hook u up, which im sure someone on the forum knows someone in cali to do it. you pay a bit extra to the guy and he'll pass
i give the guy like 20-30 bux and he'll pass me lol
make sure its ghetto place that can pass smog lmao
not all fancy and ****
