Rough Transmission shifts from 2 to 3
Old Mar 20, 2009 | 11:17 PM
Csquared's Avatar
After reading this do you guys think that we're damaging it through playing around and shifting in manual mode? So like if we go manual a lot do you think we are shortening the lifespan of the tranny?
Old Mar 21, 2009 | 10:33 AM
PeterUbers's Avatar
yes, but i don't think there is a good way to quantify how much "wear and tear" is caused.
Old Mar 21, 2009 | 02:53 PM
almatti's Avatar
That's a good point to consider. A mechanic I used in Long Island to service a 2001 Pathfinder 4WD, used to tell me that even though the PF was "engineered" to be shifted into Auto mode (4WD system when necessary) from 2WD mode "on the fly", will Get You into the Nissan Servcie Bay quickly. In other words, even though the manual and specs say it can be done, it may be engineered to breakdown so you can spend your $$$$. Having said that, I don't really think that manual mode shifting in our Gs, should damage the tranny, BUT common sense seems to indicate that it may.....
Old Mar 22, 2009 | 06:13 PM
NationsMostWanted's Avatar
hmm so you guys are taking yours in and infiniti is fixing this under warranty? mines always done that at higher RPMs and throttle position?
does it go away after the fix?
Old Mar 22, 2009 | 06:14 PM
Originally Posted by Defratos
You know mine does this too, BUT it's based on throttle position, for me at least it is. Lets say If I WOT it in 2nd and shift to 3rd at the red-line then I'll get a slight thud from the transmission.
Now if I nearly WOT (but not fully) then shift to 3rd at the red-line and as its shifting I'll WOT (i.e. Fully press the throttle down) all the way down then it'll shift perfectly with no harsh transmission thuds.
Now if I don't WOT or partially and then shift to 3rd as I'm either keeping the same throttle position or less then this is when I get the so called "harsh" transmission shift.
Play around with throttle position and gear changes, it makes a world of a difference. Whenever I have a friend drive my car for the first time they nearly always end up jerking the car like no tomorrow because they do not expect the transmission to buck like that. But then again if you WOT it in 2nd and shift to 3rd at a lesser throttle then you're bound to get transmission thuds.
yea thats how mine is? are others having this issue everytime?
Old Mar 22, 2009 | 09:12 PM
G35Now!'s Avatar
Moderation-free
+1 This is my experience too, and there have been a bunch of threads about this. It's normal, or at least very common.
Old Mar 23, 2009 | 10:10 PM
almatti's Avatar
Infiniti has replaced the valve body in the tranny when I complained about this harsh shift into 3rd, mostly in manual mode. It is better, but not as good as the sifting up and down into other gears. It seems worse when cold, but it's still THERE even as it warms up. I think others are right here, play with the throttle. It's probably a "quirk' that is intrinsic to this electronic Tranny....
Old Feb 2, 2011 | 09:35 PM
jcrayamsterdam's Avatar
Originally Posted by stevester557
Hi,
I have a 2007 G35X which has the same problem when shifting from 2nd to 3rd. Someone asked about how violent the shift is, I describe it as being rear-ended. When I rev mine up and shift from 2nd-3rd it will actually feels like someone kicked the back of my chair. I have been to the dealership several times and nothing has ever been found. I am going in tomorrow for the VDC/Slip light problem and I am going to take a tech out for a test drive. I'll keep you posted.
Stevester, sorry about resurrecting this thread but I have this problem. What happened after you brought the car to the dealer?
Old Feb 2, 2011 | 09:37 PM
Originally Posted by PeterUbers
someone recently posted a similar problem and Infiniti service told him his 2->3 clutchpack was defective and it was repaired under warranty.
if you're under warranty, why NOT take it in????
You don't happen to remember where you found that clutch pack post, do you?
Old Feb 2, 2011 | 09:40 PM
Originally Posted by almatti
stevester: I had that hard - too hard - shift to 3rd in manual mode primarliy. It seemed to get worse this winter. Also had the TSB 028 applied last year. My dealer confirmed the "hard shift", replaced the Valve body in the tranny, and it's much better. Still not as smooth as other shifts, you smooth but with firmness, but better. Had it done about 2 months ago. It was warranty work, so who knows if it Really was necessary. I've got 17k miles on the clock.
Hi Almatti, I downloaded all the TSBs for the G but can't find the one you referred to. I have a few that have the number 28 in them But they have nothing to do with the A/T. Could you tell me exactly which one? And would you happen to have a copy of the work order where they replaced the valve body? I'd like to show that to the dealer.
Old Feb 3, 2011 | 04:33 PM
Mkai0's Avatar
jcrayamsterdam, my car did this the other day for the first time after I was having some possible battery issues with my car. I haven't pushed my car hard since it did the first time, but I will be changing out my battery today with either an Optima yellow top or Odyssey battery and then see if there are any issues. My mechanic told me that these car need good batteries especially when under load. I've had my stock battery for about three years now, so I figure it's time for an upgrade. BTW I have a transgo shift kit, and I have it for about six months now with zero issues until the weird shift the other day. I don't think it was the Transgo kit though. I'll keep you posted.
Old Feb 3, 2011 | 04:34 PM
thescreensavers's Avatar
Mr.202?
The 2nd to 3rd rougher shift is 100% normal in the 5at
Old Feb 3, 2011 | 08:52 PM
@ Mkai0, how do you describe the shift?
@ thescreensavers, it really feels just like what stevester describes.
1- it feels like you just got rear ended, it isn't a bullet shift, it's jarring.
2- in my case it only happens when it's really cold outside. Once the transmission warms up (not the engine), it goes away.
Old Feb 4, 2011 | 01:37 AM
Mr.202?
lol, I have been rear ended and it does not feel like that at all :O
It just feels like a rough shift. I am 100% used to it now. I always get it when rolling out from school, COLD. I never pay attention when it happens but I need to see if it happens when the tranny is warm.
Old Feb 4, 2011 | 12:32 PM
  #30
35G'dUp's Avatar
seems like you guys only have the problem from 2-3, but i seem to have it from 1-2
