2007 G35x automatic transmission problem?
Old Feb 13, 2010 | 12:30 PM
  #31
chinaxinsanity's Avatar
i've posted about the shudder many times before, and people keep telling me it's "normal".
time for me to test out the reflash as well.
Old Feb 15, 2010 | 08:32 AM
  #32
stevec1129's Avatar
I actually haven't made it to the dealership yet I just havent had any time lately. I still plan on doing this re flash at some point. I'm still waiting on my R2C's so i should probably get this done before I slap on my intakes.
Old Mar 30, 2010 | 11:16 AM
  #33
im at the dealership right now. the ecu reflash is just throttle sensitivity, not sure if it has anything to do with shifting.
but they're reflashing and im gunna be the guinea pig here in the east coast. wish me luck, hope the shudder will disappear
Old Mar 31, 2010 | 09:22 AM
  #34
stevec1129's Avatar
what was the result of this reflash? I'm considering just bringing my car in to my mechanic and having him diagnose the issue. Then I'll just bring the results to Infiniti and make them replace either the torque converter or transmission.
Old Mar 31, 2010 | 09:40 AM
  #35
dohturdima's Avatar
Originally Posted by stevec1129
dohturdima, did the ECU update get rid of the shuddering at 40mph, if you had it to begin with? Thats the only reason i'm considering getting it done really. It also seems to shift at weird points but I've been told that if i reset my ECU after i put in my new intakes, and then go ***** to the walls for a while it will re-learn my driving. I bought this car 6 months ago and it was driven by a woman in California.
I did it primarily for the overagressive throttle tip-in, and to be honest don't recall the shuddering issue @40 mph specifically. However, after the reflash was applied the shifting did get smoother.
Old Mar 31, 2010 | 07:12 PM
  #36
ok so from my experiences so far:
there is no big shudder around ~40mph. it's semi gone for me. of course when changing gears manually you will feel the gears shift. other than that, i dont get a strong boom anymore.
Old Apr 2, 2010 | 11:06 AM
  #37
stevec1129's Avatar
I wonder if the shudder went away temporarily due to the reflash. When i reflashed my car it felt like it got a bit better and then a little bit worse again. Any update since Wednesday?
Old Apr 2, 2010 | 11:35 AM
  #38
my car seems to be a little bit smoother than before now. thats all really, so i guess the reflash helped a bit
Old Apr 13, 2010 | 12:29 PM
  #39
heynow's Avatar
I've recently bought a used '07 G35X (built 05/07). I haven't noticed the 40mph sudder until now . My shudder seems slight - compared to what has been described here, but it's there nonethless! The throttle sensitivity TSB has been applied in 08.
I've installed the Black Betty 2nd Gen grounding kit, and it's has DEFINETLY smoothed out the shift (as well the manumatic 2nd-3rd).
Should i print out the shudder TSB, and push for the tranny temp sensor replacement?
Old Feb 21, 2014 | 09:21 AM
  #40
turrifik's Avatar
Johnny you have an 08, so i believe the update for you would have been different than my 07, as this update makes the throttle/transmission in the 07's drive like the 08's. I've sent out a few PMs to see if the ITB08-017 fixes this; would you happen to know?
Thanks for all this research and problem descriptions.
I'm having a similar problem with my 08 G35x ~65000 miles. I feel an abrupt stutter/shudder in the drivetrain under the conditions most people describe, but it's very brief (less than a second) and very noticeable. Is this what you guys experience or is it a more prolonged continuous shudder that goes away after a gear change for example?
The problem is getting more frequent now (1-2 times per week), whereas I used to notice it once or twice a year when I bought the car in 2010.
I was going to flush all the fluids per the Infiniti maintenance schedule and see if I had a transmission problem. But, I hope this re-flash solves the problem.
Thanks again for all the input on this.
Old Feb 21, 2014 | 10:04 AM
  #41
heynow's Avatar
The re-flash & fluid flush just masks the problem. It never really goes away.
I'd suggest doing both anyway if you haven't yet.
Both will help, but don't think that it'll be a cure-all.
For me, adding shudder-fix with new fluid has been the most effective way of dealing with this.
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
socalg35x
Jul 28, 2015 10:42 AM
newg37
Jul 26, 2015 09:32 AM
newbdriver01
Jul 15, 2015 06:10 PM
