New Resonators?
Old Mar 2, 2009 | 12:03 AM
Csquared's Avatar
New Resonators?
Hey guys,
After installing HFCs, I find that on acceleration there seems to be a rattle or some sort only under load, After some detective work it doens't seem to be coming from the cats, but from the back, so I'm guessing that the stock resonators can't deal with the increased flow, anyone know if you can get high performance resonators or some better resonators for the exhaust? Thanks in advance!
Old Mar 2, 2009 | 12:41 AM
G35 {skyline}'s Avatar
I had the same problem after I installed my Intake.. im guessing too much flow... but after about 500 miles it just went away.. what about getting a magnaflow resonator. it makes the car growl louder too
Old Mar 2, 2009 | 01:06 AM
Csquared's Avatar
^ thanks for the input, Which resonators do you mean exactly got a model number?
Old Mar 2, 2009 | 01:15 AM
You would need 2 12615's....
here is the link straight from the Magnaflow site:
http://www.magnaflow.com/02product/s...e=main&id=7941
Old Mar 2, 2009 | 01:34 AM
Csquared's Avatar
Thanks Much appreciated! Wow they are expensive though lol.
Old Mar 2, 2009 | 01:45 AM
K0nArtist's Avatar
You can get those on eBay for 65 each.
Old Mar 2, 2009 | 05:00 AM
Phalanx's Avatar
Did anyone try a true dual exhaust with H pipe and no resonator at all? I mean just the HFC and H pipe and then straight pipe all the way to the muffler. If yes, please share with us the sound clip.
Old Mar 2, 2009 | 03:03 PM
Csquared's Avatar
Thanks guys, I'll look into these a little later. I know there are videos of people who just cut out the resonators, and honestly i think that sounds really bad, so i don't think increasing flow with with HFCs and a H pipe would make it sound nicer, I don't know you can try it!
Old Mar 2, 2009 | 07:12 PM
Csquared's Avatar
Wait I did more research on Resonators, apparently they are designed to reflect certain sound waves that the engine makes and then bounce them off to cancel out other sound waves. So I Can i just stick a different resonator on? From Physics I know that if it's not not I'll just be getting a bunch of even more unwanted noise!
Old Mar 2, 2009 | 07:54 PM
Csquared's Avatar
Umm also the 12615 are mufflers but they will work as resonators?!
Old Mar 5, 2009 | 04:27 PM
2GoRNot2G's Avatar
A resonator is nothing more than a tubular muffler that is designed to knock out a lot of the unwanted frequencies out of the the exhaust system. I actually used this same exact one, only in 3" on my eclipse GSX years ago to get rid of the incesent droning I had on the highway.... It worked perfectly for the intended job.
Old Mar 5, 2009 | 04:30 PM
Csquared's Avatar
Thanks Adrian, I'm gonna try to replace my Y pipe and see if that get rids of the rattling if, not i might move on to these resonators.
Old Mar 5, 2009 | 04:56 PM
kejolly's Avatar
Csquared,
were you able to look under the hood and see if the headers have a heat shield yet?
Old Mar 5, 2009 | 05:04 PM
Csquared's Avatar
From what I noticed there seems to be a heat shield so when you look from the engine bay you can't see the headers. but if it was the headers hitting those heat shields everyone should have the rattle with stock setup.
Old Mar 5, 2009 | 05:06 PM
agiraldo182's Avatar
Its the HFC HISSSSSSSSSSSSSSS.............
That's why i took mine off
Unfortunately, what a sub-par product
