Nissan Power Pup Bullydog - First Impressions
Old Jul 21, 2009 | 11:48 PM
  #631
kendroz's Avatar
Originally Posted by Iilac
Yeah, what's your email address?
*email removed
Thank's
:edit:
send him a PM if you don't want spam bots to grab your email addy
Old Jul 22, 2009 | 09:48 AM
  #632
a0s4957's Avatar
Has anyone tried the 1.23b? I got this from BD yesterday and when I tried to upload into the ecu it prompts me to call BD...???
Old Jul 22, 2009 | 11:52 AM
  #633
Austin713's Avatar
Thanks for your response, I have been driving it, although I haven't got too much miles on it yet but I don't really feel the BD tune. It does rev up to 8000 and I assume the speed limiter is gone, maybe I have to drive it some more to take effect? I am stock though.
You will start to notice it after a while, you should also see a gas mileage increase as well. ECU has to sort of get used to the tune.
Old Jul 22, 2009 | 12:50 PM
  #634
kool_yaar's Avatar
All right after a lot of thinking i too am CONSIDERING of "tuning" my car and this seems to be the most viable option for the price, so anyone about to get any dynos or 1/4 or such? Also any confirmation whether the BD caused any of the problems that a few ppl had with their cars?
Old Jul 22, 2009 | 06:51 PM
  #635
ced357's Avatar
Just did the tune, nothing noticeable yet. However, I am hopeful. I'm going to use my iphone dyno after a few weeks of driving to see if there is any change from my baseline results with the iphone.
Oh, by the way, I required version 1.23b if anyone needs it.
Old Jul 22, 2009 | 09:22 PM
  #636
a6g35's Avatar
Question about returning back to stock
Hi. I'm trying to return the ECU back to stock. Bully dog has been running for nearly 45 minutes now... and its been stuck on 0% @ the downloading screen.
Anyone else have this ? or am I just not patient enough?
Installing didnt take this long...
UPDATE: after about 1.5hrs stuck on 0% i unplugged it from the car. started the car to check if everything was ok and turned off the engine. plugged BD PP back in and it seems everything is running fine and the tune is still there. Guess i'll try again tomorrow.
Old Jul 23, 2009 | 09:58 AM
  #637
Austin713's Avatar
That has happened to me before. just back it up to the factory tune and then reinstall the BD tune to make sure.
Old Jul 23, 2009 | 10:51 AM
  #638
kool_yaar's Avatar
^ i think he''s just trying to get back factory tune and not BD tune... strange problem keep us updated
Old Jul 23, 2009 | 11:16 AM
  #639
InTgr8r's Avatar
Staff ALUMNI (retired)
I think he's still on factory tune.
The DL didn't go through. "stuck at 0%"
...probably doesn't have a good file yet.
I'm still in the holding pattern as well.
Talked to tech yesterday & they're still working on it.
I'm not too concerned though, I still want to arrange a base line pull before I install it.
.....just haven't had the time.
Old Jul 23, 2009 | 12:01 PM
  #640
a6g35's Avatar
I already did the premium tune and I was trying to return the car to stock last night. (Need to install paddle shifters). But it got stuck on 0% @ the download stage while trying to return to stock. According to PP, I still have all the tuned settings on my car in the "view settings" screen. However, the car is different today from yesterday.
Ex: My idle rpm at startup previous to this incident was above 2100rpm. But this morning, my idle rpm at startup was no more than 1800rpm. The throttle feels a little different too. not sure. I'm hoping PP didnt return my car to stock but still keep my engine code on the PP unit.
I'm going to try and "return to stock" again tonight.
Old Jul 23, 2009 | 07:17 PM
  #641
jack090's Avatar
Keep us updated. Just an update on my vehicle...... no problems to report.... I put at least 30+ miles a day on my vehicle and haven't had any problems. Had my fluids checked and oil change changed. I'm still rocking out 1.22b (need to update eventually). I did take the +2 timing off because I'm trying to get a dyno run scheduled with my local shop. (Will do a +2 timing and a neutral timing).
Old Jul 23, 2009 | 09:00 PM
  #642
a6g35's Avatar
Tried again tonight. When it got to 0% downloading stage, the engine fan kicked on and it started to run immdiately. So no problems. was able to return to stock.
Old Jul 23, 2009 | 09:12 PM
  #643
InTgr8r's Avatar
^good to hear
Old Jul 28, 2009 | 06:55 PM
  #644
ced357's Avatar
so I've driven about 150 miles on my BD tune and have felt nothing. I've compared my 0-60 time before and after using my dynolicous and have the same results. Do you think its too early to see results? Maybe I need more miles for the ecu to adjust? Any thoughts?
Old Jul 29, 2009 | 11:29 AM
  #645
Austin713's Avatar
Did you Bump the Timing? seems like that would have the most effect for performance. i gained 1-2 MPG
