Anyone else have this on their G?
Old 07-05-2009, 02:56 AM
Defratos's Avatar
You're Despicable
^ Where are you located?
Old 07-07-2009, 03:33 AM
Q8y_drifter's Avatar
One more top view I took through the radiator cover
Old 07-07-2009, 04:43 AM
Defratos's Avatar
You're Despicable
Ohh nice pic dude, looks much clearer now, I'll see if I have one as well (I know I've already said it before) but I'm in the process of moving houses so I'm a bit busy
Old 07-07-2009, 09:30 PM
soundmike's Avatar
US-spec G35s here and i have it. It's about 8-10" wide by roughly half that high, it's in front of the lower portion of the radiator on the passenger side, probably because of the ICC.
Old 07-08-2009, 12:34 AM
terrycs's Avatar
I'm curious ... trace the hose on top and tell us where it goes.
Old 07-09-2009, 10:39 AM
4drsleeper's Avatar
08 Journey and I have one. I always assumed it was an oil cooler.
Old 07-18-2009, 09:11 PM
NETSHARK's Avatar
Thats cool so not only the GTR got one lol
Old 07-25-2009, 06:30 PM
G35s-Q8's Avatar
I can confirm this as Transmission oil cooler, i went to the dealer and checked it out.
Old 07-26-2009, 03:29 AM
Defratos's Avatar
You're Despicable
Sweet , so can this be upgraded simply by buying an aftermarket transmission cooler core? or would we need the whole kit to go with it? i.e. can we use the existing wires?
Old 07-26-2009, 05:19 AM
G35s-Q8's Avatar
Yes, all you need is the core, you can use the existing hose if they're flexible, but if they are molded in special way like radiator hose's then you'll need to find a way to make them fit into the new core.
I might go with a bigger core, or buy B&M cooler with fan, last night i was racing in my car, after 3-5 runs the transmission shifts got different because of the oil got hot.
Old 07-26-2009, 07:19 AM
Defratos's Avatar
You're Despicable
Sounds sweet, I'll wait until you do it lol I'll let you be the Guinea pig
also looking at the pic above it looks like the upper hose is only being secured by one of those crimple grip thingies, not too sure how the bottom one looks. I'll try and see tonight
Old 07-26-2009, 11:09 AM
G35s-Q8's Avatar
I went for oil change today and noticed that we have that cooler from Post#13 on our car too.
Old 07-27-2009, 10:32 AM
G35s-Q8's Avatar
I've measured our OEM transmission oil cooler and it was 10"x4.5"x1, i've ordered B&M transmission oil cooler which is 8"x11"x1.5" which is double the size, i'm sure there well be cooling results, but i don't know how much.
I was reading about transmission oil coolers and that cars without them can get their oil temp up to 230-250f when WOT, so i think it's a must for everyone tracking or racing with 5AT.
Here's the B&M i've ordered:
http://www.summitracing.com/parts/BM...2/?image=large
Old 07-28-2009, 05:12 AM
Defratos's Avatar
You're Despicable
Damn looks sweet dude, can't wait to see it installed
  #30
Old 07-28-2009, 05:22 AM
G35s-Q8's Avatar
It'll arrive this week, and i'll install it once i get it, the problem is i don't know which hose is the inlet or the outlet, but i'll find a way to fit it on the stock mounts of the old oem cooler, i guess i'll cut and trim the stock hose's.
