problem with my 6mt
Old Jul 29, 2009 | 03:33 AM
firozu's Avatar
problem with my 6mt
soooo dealership said i need a new clutch because it is worn out causing it to slip.
took it to another mech. for a second opinion and he said there might be an adjustment on the clutch.
basically heres my problem in any gear if i hit the gas after it has already been in gear it'll slip out nd rev high and drop. ex: im in sixth gear hit the accelerator and the rpm will jump from 2 to 3 thousand and then drop baq to 2 and continue normal opperation but i will feel the jump and loss of power..
Old Jul 29, 2009 | 08:27 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
what year is your car & how many miles?
Old Jul 29, 2009 | 10:49 AM
Austin713's Avatar
try this.... get it up to about 40 and put it in 5th. turn VDC off and put your foot to the floor. if your revs go up without the cars speed increasing at the same rate then your clutch is slipping. How many miles?
Old Jul 29, 2009 | 11:16 AM
kool_yaar's Avatar
According to OP's comments his clutch is gone, anytime you see the rpm fluctuate while in gear when you press the accelerator you have a bad clutch.
Old Jul 29, 2009 | 12:20 PM
InTgr8r's Avatar
^ I agree.
Old Jul 30, 2009 | 07:22 AM
snowcrossmxz's Avatar
^ +2 it is a clutch,
Old Jul 30, 2009 | 07:38 PM
firozu's Avatar
welp thats what dealership said as well...grrr was hoping for something else but meh... so it looks like jwt $799 clutch combo huh? unless u have any other suggestions
btw its 07 42,600 miles
brownie
Nov 25, 2015 12:50 AM
Eomfd
Aug 29, 2015 12:42 AM
derres
Aug 28, 2015 03:27 PM
NemesisGee
Aug 11, 2015 07:10 PM
TreeFiddy
Aug 10, 2015 06:50 PM
