clutch pedal on the ground
Old Sep 11, 2009 | 11:38 PM
firozu's Avatar
clutch went to the grounda nd wont come back up i was pretty sure its because the clutch is fully burned out but now im getting second thoughts/opinions and thinking its the slave cylinder? any thoughts???
Old Sep 12, 2009 | 12:02 AM
james0076ss's Avatar
You should get that checked out... Hopefully you still have a warranty
Old Sep 12, 2009 | 12:08 AM
Texasscout's Avatar
They will tell you "you need a new clutch". Before you spend $2000 at teh stealership, tell them to flush and bleed the Clutch Master Cylinder and Clutch Slave cylinder. Fixed mine right up and it's been a year now with no problems.
Old Sep 12, 2009 | 12:22 AM
kool_yaar's Avatar
I hope you are aware that infiniti took out a voluntary slave cylinder replacement recall a while back which pretty much addresses your problem, when the clutch is stuck to the floor. Open you hood and chekc the clutch master cylinder the fluids should be gone...
It's a recall so you should be covered 100% unless you already had this done... search for the recall notice here or on infinitihelp and take it with you to the dealer
Old Sep 12, 2009 | 12:26 AM
kool_yaar's Avatar
Link to same problem btw i alsi had this same issue with the clutch being stuck all the way to floor over 1.5yrs ago even before the recall came out and they replaced the slave cylinder and everything has been great so far touch wood.
Old Sep 13, 2009 | 09:39 PM
firozu's Avatar
well heres the thing ive been having problems with my clutch slipping for the longest time...so idk if it mayb really is burned out?
if i check the fluid and the fluid is gone that would mean its definitly the slave cylinder or is there a possibility its still the clutch im just tryin to find out what to do now cuz the car cant move i already ordered the clutch so what are your suggestions??
Old Sep 13, 2009 | 11:13 PM
Texasscout's Avatar
No, the problem the OP has was not a worn clutch. What you discribe IS a worn clutch.
Old Sep 14, 2009 | 12:37 AM
firozu's Avatar
i am the op...lol and i had the slipping problem and now the clutch pedal is on the ground
Old Sep 14, 2009 | 12:42 AM
tonke73's Avatar
Those could be 2 different issues. Clutch slippage is your clutch disk wearing to the rivets. A clutch going bad won't cause your clutch pedal to stay stuck on the floor.
The clutch pedal to the ground is most likely your slave cylinder like others have posted.
Old Sep 14, 2009 | 08:09 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
In this case, probably both.
Old Sep 14, 2009 | 10:05 AM
Scooby24's Avatar
As others have said, pedal to the ground = no hydraulic pressure so master or slave cylinder issue.
There's no scenario in which case your clutch being worn would cause this problem...unless your pressure plate is getting stuck fully compressed...which I've never even heard of happening.
Old Sep 14, 2009 | 11:18 AM
firozu's Avatar
So is there a possibilty that a bad slave culd have caused the clutch to wear/ burn?? And how do I go about fixing this issue shuld I juss call infiniti and tell them what happened??
Old Sep 14, 2009 | 11:26 AM
Scooby24's Avatar
Yes, without adequate hydraulic pressure, you pushing the clutch all the way down might not have fully disengaged the clutch and caused unnecessary slipping of a partially engaged clutch at all times.
However, if you've got more than 20-30k miles, it'll be like pulling teeth to get them to agree to warranty both the slave cylinder AND a new clutch. They might pick up a portion of the cost though on a new clutch.
And yes, take it in, the slave cylinder should be a powertrain warranty item.
Old Sep 14, 2009 | 11:31 AM
Rutland's Avatar
Sounds like the slave cylinder recall to me.
Old Sep 14, 2009 | 12:13 PM
firozu's Avatar
The thing that upsets me is I mentioned ther recall to them b4 when I started havin the clutch problems and bcause I'm a 19 yr old kid I guess they juss ignored me and now I need it changed when I culdve avioded this prob all together...orlando infiniti has horrible service and ppl who don't know anything about the cars that they work on..
