Can you put auto to N while driving?
Old Sep 26, 2009 | 03:01 AM
  #31
pfarmer's Avatar
Originally Posted by kregg
I am putting it in 5th, that's what the + paddle does. Since I am decelerating or trying to coast I am not hitting the gas , I think you misunderstood.
I use the paddle shifter mostly for downshifts if it 'D'. However if I was to try to lock it into a gear I would put it into DS so it doesn't shift back after about 5 seconds of straight line travel.
Old Sep 26, 2009 | 05:01 PM
  #32
kregg's Avatar
No need to put it in DS for this (for me at least). 95% of the time it holds long enough to do the trick in D, even very long descents, it seems to know what I am doing and holds 5th for an extended amount of time. On flats sometimes (the 5%) it does switch back to D quickly, but one more tap of the + does the trick, or I just leave it in D as like I mentioned before I don't think this really does much.
Old Sep 27, 2009 | 01:58 AM
  #33
pfarmer's Avatar
If I remember correctly it stays in for something like 5 seconds unless it senses otherwise (such as going around a corner, etc.). So it may be that going downhill will hold it in as well. But if I wanted to keep it in I would typically want to lock it in. Seems like it would be just as easy to place it in DS and place it in 5th for this purpose.
On the other hand I actually do something similar. When I enter a round about I typically will in 'D' put it in 2nd or 3rd to keep it from doing a strange downshift on its own. It will stay until after exiting the round about.
Terry_G35
May 9, 2020 01:39 AM
mjfenix
Aug 17, 2017 05:49 AM
Th611
Oct 27, 2015 03:48 PM
Terry_G35
Aug 4, 2015 02:38 PM
Jadenkid22
Jul 14, 2015 12:33 AM
