G35 30K Service at CarZone Auto Repair
Old Oct 10, 2009 | 07:30 PM
Rizzagt22's Avatar
Hey guys, just had my car serviced at CarZone Auto Repair in Van Nuys (Certified Nissan-Infiniti Master Mechanics). The guys there are great and do excellent work. The following service was performed:
* Replace Motor Oil with Mobil1 5W-30
* Radiator flush and replace with OEM Coolant
* Replace Rear Differential oil with Valvoline 75W-90
* They even checked the A/T Fluid and showed me how clean it was and still good for atleast another 15K miles, even though the owners manual reccomends replacement at 30K miles.
Total including parts & labor $137!!
They finished all the work in about 45 minutes, quick and convenient. They got my business for sure.
Old Oct 11, 2009 | 06:25 PM
Austin713's Avatar
I checked my coolant the other day and it was still brightgreen. Congrats on the great deal, how did your rear diff fluid look?
Old Oct 11, 2009 | 08:22 PM
Rizzagt22's Avatar
Agreed Austin, my coolant was clean as well so therefore I wont be servicing that item again for as long as I own the vehicle. The rear differential fluid on the other hand was really dirty and the drain plug had a lot of shavings and grease on the magnet portion of it. The mechanic explained that when they assemble the gears in the differential they utilize grease, etc and dont both to flush the differential and just simply fill it with the oil. Hence the first drain will always look really dirty.
Old Oct 11, 2009 | 10:05 PM
pwebb's Avatar
30k service should also include
air filter
cabin filter
wiper blades
rotate and balance
Old Oct 12, 2009 | 10:36 AM
Rizzagt22's Avatar
Pwebb, I had replaced my Air Filter(s) at my previous oil change and the cabin filter I plan on replacing soon. The wiper blades work fine and the wheels on my car are staggered therefore cannot be rotated. Balancing is not always necessary unless you feel vibration in the wheel upon applying the brakes.
Old Oct 26, 2009 | 10:27 PM
vegas160's Avatar
I just went to the dealership and they said that they use a different type of ATF that you cant get from the market. Is that true? Cause the dealership charge a arm and a leg to change whereas i can get it changed from somewhere else at half the price. Also the rear differential, should it be replaced at 30k cause i havent done mine and im at 46k. Im gonna wait on the coolant until 60k.
Old Oct 31, 2009 | 04:57 PM
JDM_Cain's Avatar
ijust hit 30k on my Sedan, i might hit them up to service my car. Thank you!
Old Nov 2, 2009 | 06:22 PM
JDM_Cain's Avatar
I went to the shop today and got the Radiator Flush, Diffirential oil change, and motor oil change with Mobil 1. Great service, fast and efficient. You guys can talk to Donald, he will hook you up. Tell him youre from g35driver and know Chris.
Old Nov 2, 2009 | 06:46 PM
pfarmer's Avatar
Nissan Matic S?
Old Nov 2, 2009 | 07:31 PM
nghiars's Avatar
137 for all thats pretty cheap.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
RedBaronK
Jul 27, 2015 06:25 PM
laksjd84
Jul 24, 2015 05:12 PM
igking
Jul 19, 2015 01:12 AM
