Question for those with a FI exhaust
Old Nov 1, 2009 | 11:32 PM
ramo's Avatar
I had my FI exhaust installed a couple of months ago, and just recently I noticed a sound coming from the bottom of the car when I hit a bump. i took a look under the car and it seems that the cross brace under the car is very clost to the mid muffler. Did any of you guys take that brace off?
Old Nov 2, 2009 | 12:41 AM
terrycs's Avatar
My cross brace is still on.
Old Nov 2, 2009 | 01:59 PM
Austin713's Avatar
mine is still on. make sure you put it back on correctly if you flip it over it will contact the exhaust. i would also go back under there and check all your bolts for tightness.
Old Nov 2, 2009 | 02:14 PM
Defratos's Avatar
You're Despicable
Lucky F.I B@stards, stop rubbing it in our face
Old Nov 2, 2009 | 03:57 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No problem with mine either.
Old Nov 2, 2009 | 04:07 PM
suby01's Avatar
i had to bend my brace downwards for the exhaust to fit. its still on but its bent because the mufflers wouldnt fit.
Old Nov 2, 2009 | 08:34 PM
aooooo's Avatar
mine is fine
Old Nov 3, 2009 | 06:47 PM
johnblaz2000's Avatar
Mine is fine too.
Old Nov 3, 2009 | 07:56 PM
kool_yaar's Avatar
mine is on and not hitting without any modification to it.
Old Nov 3, 2009 | 08:33 PM
B L U E S L A T E's Avatar
Honda Accord
I put a couple of washers on to space out a bit more... when I had it.
Old Nov 3, 2009 | 10:49 PM
Glover997's Avatar
i had this issue too . . i just bend it a lil downward n it's OK now !
it's not a big problem . . don't worry. you just try to bend it downwards a lil n then you're fine . .
Old Nov 14, 2009 | 05:58 PM
IvoryPearl07G's Avatar
mine hit. so i put spacers and longer bolts on. i then had a big issue with rubbing it on bumps. so i took it off.
Old Nov 15, 2009 | 09:12 AM
wreaks's Avatar
No problems with mine and plenty of clearance. I would check to make sure that the mid section is oriented properly. You may have it flipped up side down. Didn't need any spacers to get the clearance for the brace.
Old Nov 21, 2009 | 01:39 PM
AesonVirus's Avatar
I get a sound once in a while but I'm not sure if it's the brace or if it's the heat shields in the rear.
It only happens on crazy big bumps.
Old Nov 23, 2009 | 03:00 PM
InTgr8r's Avatar
I wonder if this is a generation thing.
It's possible that FI tweaked the system.
The cross brace on the GTSpec 6point brace is even bigger than the OE brace,
& still no issue on my car.
