Calling : Stillen Exhaust Owners
Old Nov 13, 2009 | 07:49 PM
OMG35S's Avatar
Question Calling : Stillen Exhaust Owners
I just bought the Stillen exhaust used from someone locally. What was included in your Stillen Exhaust? It seems to be missing the piping from the cat to the resonators....
http://www.stillen.com/image.asp?/pr...ges/504375.jpg
^ that pipe in the front of the car was not included in the exhaust?
Is that a Y - Pipe?
He actually did the install for me and it sounds good but I think that pipe is suppose to come with the exhaust?
Will it hurt anything if I leave it the way it is without that pipe? Will it affect back pressure? I just forked over some cash for it and now I'm a little disappointed that it didn't come with it...
Any suggestions?
Thanks,
Adam
Old Nov 13, 2009 | 09:16 PM
EnviedG35's Avatar
That should have included the piece from the cats to the y pipe. The stock y pipe is garbage....but the stillens y pipe is much more free flowing. Seeing as you only have half the better y pipe design you're still gonna get some restriction.....i say the hell with it and get a custom x or h pipe put in and really see some gains.
Old Nov 13, 2009 | 11:16 PM
OMG35S's Avatar
Ok, I still don't completely understand my situation. The part that connects the cats to the resonators is not the complete y pipe?
I know it's one of the most restrictive parts of the exhaust. I am dissapointed because I didn't realize it until it was installed.
Would using the stock oem pipe that connects the cats cause any negative results combined with the bigger tubing of stillens system.
I researched and it was said it was ok to use a smaller y pipe then the exhaust but if it were the other way around it would negatively affect back pressure.
Any reccomendations? If I did want to add a x or h pipe would I have to weld or cut anything? I quite don't understand how that peice that I thought was a y pipe that connects the cats would be replaced with an h or x pipe...
Can someone please enlighten me on this subject?
Thanks
Old Nov 16, 2009 | 10:59 AM
Q8y_drifter's Avatar
you can't really replace the y-pipe with an x-pipe without modifying the resonators pipes. You should have also gotten the y-pipe with the exhaust kit. There are no negative effects on using a stock y-pipe with the Stillen exhaust but it's best to use the Stillen y-pipe for best flow.
Old Nov 16, 2009 | 12:15 PM
suby01's Avatar
+1
your not going to damage anything with it as it is now. just your not getting all the gains without it to keep it simple.
Old Nov 16, 2009 | 12:48 PM
OMG35S's Avatar
Thanks for the info... I'll be purchasing the Y-Pipe separately from Stillen next week.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
derres
Aug 28, 2015 03:27 PM
Spartan268
Aug 20, 2015 09:14 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
