Dry Performance Air Filters
Old Dec 28, 2009 | 09:17 PM
mikeb2's Avatar
I installed new stock air filters when I bought my car but it's getting time for a change. What is the general consensus for dry performance filters. I don't want to get involved with the wash and oil job, just a drop and discard deal.
Thanks..
Mike
'07 G35x
Old Dec 28, 2009 | 09:30 PM
tg1234's Avatar
I've got HKS drop in filter for my G. I clean them every 3k with airgun and was and /dry/clean every 6k. No issue here.
Old Dec 29, 2009 | 09:53 AM
johnnyzee's Avatar
^same here, using HKS drop ins, just not cleaning them as often.
Old Jan 3, 2010 | 08:15 PM
mikeb2's Avatar
Well, after a minimum amount of research, I think I'll go with a pair of K&Ns because they seem to be a fairly wide choice and I can get a deal on them through my local jobber. Does anyone have an opinion that I should not use those?
Thanks...
Mike
Old Jan 3, 2010 | 08:37 PM
johnnyzee's Avatar
Well, I went with the dry because I recall an issue on my friend's Altima (06), where the MAF sensor got messed up and needed to be replaced due to oil residue getting on it from his K&N. Both dealer and his "mechanic" confirmed this.
Now, I don't know how accurate this is, but I figured to play it safe, the G also being a Nissan product, I try to avoid giving myself issues if I can. I do however use K&N on my Camry, and haven't had any issues.
Old Jan 3, 2010 | 08:59 PM
mikeb2's Avatar
I believe that I read that K&Ns can be over-oiled. That could be an isse. Raed the intructions, I guess.
Mike
Old Jan 3, 2010 | 09:28 PM
tg1234's Avatar
I went with the dry since It seems less chance to screw up. LOL As you said maybe little too much oil, etc. I just did not like the idea topay for filters all the time.
Old Jan 3, 2010 | 09:42 PM
NCG35S's Avatar
I have used K&Ns on many Mustangs and have a drop-in set on the G.
To help prevent any issues, "pat" the new or freshly oiled filters down on a paper towel prior to install.
Old Jan 4, 2010 | 04:25 AM
Defratos's Avatar
You're Despicable
I've just bought K&Ns but haven't installed them yet.
You will mess up your MAF if you over oil the filter and don't let it dry.
I've used K&N on my Audi S3 for 5 years and no problems at all, although my bro used it on his Golf and at one point he did have a problem because he over oiled the filter and didn't leave it to dry.
I'd just make sure to not over oil it and make sure it's dry and you should have no problems at all.
Old Jan 4, 2010 | 09:27 AM
jane's Avatar
Had K&N's forever. After I clean and oil I let it sit in the sun all day to dry real good. No problems. I only do mine every other year. In between just take out and tap on ground to clean abit.
Old Jan 4, 2010 | 03:20 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I used the Amsoil EaA dry nanofiber filter on my 1st gen & loved it.
But, it doesn't look like the make a 2nd gen filter yet.
..I'd definite use one again if available.
Old Jan 4, 2010 | 06:35 PM
johnnyzee's Avatar
Never asked, what's your opinion on the HKS Ian?
Old Jan 4, 2010 | 07:09 PM
InTgr8r's Avatar
Never tried HKS filters.
How do you like them?
Old Jan 5, 2010 | 03:57 PM
johnnyzee's Avatar
^Can't complain, they've been in for around 10k kms. I won't even try to estimate or describe any gains as they're miniscule at best, but I will say it felt a bit "peppier" when I first put them in. Now I just got used to it.
Heres the 3 layer pic:
Here's a full filter pic:
and here's their description:
Super Hybrid Filters
HKS’ high-performance Super Hybrid Filters are a direct replacement for OE panel filters when a factory airbox is required or preferred. Super Hybrid Filters features a 3-layer dry-type filter. The filter element is bonded to a flexible nylon frame and offers a price-friendly performance alternative to a full intake system.
Old Jan 5, 2010 | 04:19 PM
InTgr8r's Avatar
Thanks.
I definitely want to stay a dry type as well.
