vibration?
Old Mar 1, 2010 | 11:44 AM
Ggosht's Avatar
Exclamation vibration?
hello,
i have invidia exhaust and there is some vibration when i shift to N do you guys with invidia exhaust have this vibration? any idea how to stop it ?
Old Mar 1, 2010 | 03:23 PM
Q8y_drifter's Avatar
are all the exhaust mounting point and bolts tight?
Old Mar 2, 2010 | 11:11 AM
Ggosht's Avatar
yes they are very tight
Old Mar 2, 2010 | 11:24 AM
mishmosh's Avatar
You should look under to see if there is any rubbing anywhere. The fitment of my Borla was not great and I had to tweak the position several times to get it not to rub against something. Mainly, it would rub against the plate in the middle (underneath it) or around where the rear sway bar is.
Old Mar 2, 2010 | 02:24 PM
Defratos's Avatar
You're Despicable
I had a slight rattle when I installed my Invidia, it turned out to be the 4 bolts (2 on each side) the ones that are above and slightly behind the exhaust tips.
They came loose and I just had to tighten them once
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
