what's your rpm range, mine is at 7700?
Old Mar 18, 2010 | 09:57 AM
headshot's Avatar
When I put my foot into it (WOT) it shifts at 7700. Is this what others are doing. This car pulls hard and fast. I am so impressed with this V6 power. This thing would run circles around my old GT Mustang.
Its a all stock 08 G35 Sedan Sport. Bought it from a board member from the Nissan Plant in Mississippi with 15k mile, full warrant, like new condition, built late in 2008. Not a mark on the car.If I didn't know any better I would think this thing has been professionally tuned.
So is the 7700 rpm normal? It dips right into the red before shifting.
Old Mar 18, 2010 | 11:47 AM
EnviedG35's Avatar
You're fine. The rpm gauge isnt going to be dead on anyway, most of the time. Just make sure when using manual mode you shift before redline because it will run into redline and then the ecu will cut power to prevent damage.
Old Mar 18, 2010 | 12:47 PM
kool_yaar's Avatar
^+1 even if shows that its dipping into red it would actually not be, it will shift at the 7600rpm line. And like envied said when using manual mode shift a few hundred rpm before the redline to avoid fuel cut
Old Mar 18, 2010 | 01:09 PM
LakeShore_Slate's Avatar
yea before my tune it was about that now its almsot right on 7900 its like being on a bike
Old Mar 18, 2010 | 01:31 PM
headshot's Avatar
Thanks for the reply guys. With this said what would be a safe limit on setting the rpms. I am installing the hypertech sport programmer this weekend. Opinion, what should I set the max rpm at? I guess maybe its best stock? It would be hard to determine w/o a dyno I guess. All depends where the power curve is???
welery's Avatar
before the G35 i had an ap1 S2000. 9000rpms every single day... i miss it.
Old Mar 18, 2010 | 01:37 PM
kool_yaar's Avatar
@headshot i would stay under 8000rpm and 7800 should be ideal as after that you power curve starts to drop
Old Mar 18, 2010 | 01:47 PM
headshot's Avatar
7800 - Seems like a safe zone and especially if it the power drops after 7800.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
