acceleration issues / alot of smoke out of exhaust
Old Apr 12, 2010 | 03:38 PM
platinumg35x's Avatar
Okay, I have two issues.
1) When I am cruising around 70 and want to go faster (so I hit the gas hard), there is a lag (about at least 2 seconds) before the power kicks in. It's kind of like a turbo lag. It's a very annoying lag. Does anybody else have this issue and is it something the dealer can resolve?
2) A week ago, I started my car and a lot of smoke came out the exhaust (A LOT) and gave out this burning smell. But it hasn't happened since and has only happened once. Any input?
Thanks in advance.
Old Apr 12, 2010 | 04:18 PM
Glover997's Avatar
you don't have to worry about the lag , it's normal , I guess !
as for the smoke . . what is it color ? black . . white . . ?
Old Apr 12, 2010 | 04:32 PM
the smoke was white. seemed like the smoke smoke that comes out when you start the car, but just an insane amount.
Also I heard that an ecu reflash from the dealer may fix the lag problem? Has anybody have this done? Does it even exist?
Old Apr 12, 2010 | 07:45 PM
AesonVirus's Avatar
The smoke is an issue.
Bring it in.
Old Apr 13, 2010 | 04:03 AM
Glover997's Avatar
then u got a problem with the air/fuel mixture . .
take it to the dealer !
Old Apr 13, 2010 | 10:12 PM
IvoryPearl07G's Avatar
did you have an oil change recently? it could of been overfilled.
or worse, a leaking headgasket. check the compression in the cylinders.
the lag is the acceleration wave they program into the ecu from the factory.....get a reflash to eliminate it. technosquare did wonders on my car.
Terry_G35
May 9, 2020 01:39 AM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
andyg35c1
Aug 29, 2015 03:37 PM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
