AMSOIL ATF drain fill
Old May 12, 2010 | 09:48 AM
pianofrk4's Avatar
Hi guys,
I know there's TONS of threads about transmission fluid changes etc...
But i couldn't find one that mentions anything about mixing AMSOIL synthetic ATF with Matic-J. I plan on doing a drain and fill only.
Anyone here use AMSOIL ATF?
I know I should be using Matic-J or Matic-S for that matter...but i've already bought a case of AMSOIIL ATF and would like to use it.
Any side effects after mixing AMSOIL and Matic-J? (I think there's matic-j in my '07 G35x that is being used).
Please don't flame..i did search..and read 99% of the threads... I did see BythBay mention something on this... but i can't find that thread anymore...
Any input would be much appreciated . thanks guys!
Old May 12, 2010 | 10:01 AM
heynow's Avatar
I really wanted to flush my tranny with AMSOIL.
After doing a ton of reading, it looked superior to any ATF out there.
However, keep in mind that if you ever need warranty work for tranny issues, you will be denied - since the dealer can easily tell that you don't have J or S in there.
Also, if you search for ATF on AMSOIL's site by car, you'll see that they will reccommned using J or S instead.
Having read that, i went to the dealer with a case (11QTs) of Matic S and got a nice full flush
Get a flush, the tranny holds about 11QTs of ATF. If you do a drain/fill, you only change 5QTs at the most!
Old May 12, 2010 | 10:07 AM
pianofrk4's Avatar
hmmm... i should still have warranty left on my '07. how much did that flush cost? did you buy the matic-s from ssomewhere else?
I guess it looks like i have to store my AMSOIL ATF until warranty's up.. lol.
Old May 12, 2010 | 12:09 PM
heynow's Avatar
uhhh...the fluid is prolly the cheapest here:
http://www.g35parts.com/Nissan-Matic...9mp-mts00p.htm
You might as well return the AMSOIL, fluids have shelf life.
The labor for the flush is around $90
Old May 12, 2010 | 01:20 PM
pianofrk4's Avatar
oh.. haha.. didn't know about shelf life. Thanks for that info the AMSOIL is going back then. Thanks again for the info bud! Much appreciated
Old May 12, 2010 | 01:55 PM
heynow's Avatar
no problem
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
G35CO
Sep 4, 2015 09:27 AM
