Differential Swap
Old Jul 15, 2010 | 07:48 AM
G35Robby's Avatar
Question Differential Swap
I'm planning on swapping on my non-lsd diff to a lsd differential.
But the question is can i swap it with a manual diff on an auto tranny?
Old Jul 15, 2010 | 10:30 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
The diff is the same physical size but I'm not sure if the R&P are the same ratio.
Old Jul 15, 2010 | 01:46 PM
G35Robby's Avatar
Whats the R&P?
Old Jul 15, 2010 | 03:34 PM
terrycs's Avatar
Originally Posted by G35Robby
Whats the R&P?
ring / pinion. Basically meaning final drive ratio.
Old Jul 15, 2010 | 04:46 PM
G35Robby's Avatar
Oh, i would be changing those out to a higher ration for better acceleration for the track.
Well once i find out this can work out, im going to get it fully built with Cusco Type-MZ LSD, Central 20 3.9 R&P, and nismo rear diff cover.
I want that extra kick you know. I herd it can be done but i might lose my cruise control.
Does the auto G35S come with LSD or only manuals.
Not to be mistaken with VLSD.
Old Jul 16, 2010 | 02:51 PM
Austin713's Avatar
all sports comewith a LSD. if you are going to put in an aftermarket LSD why bother changing the cases?
Old Jul 16, 2010 | 03:02 PM
LightsOut's Avatar
SIETESG
go with a 3.7 vlsd.
shorter gears for n/a..and its oem
I just read a whole thread based on diff swapping but it was all based one oem diffs.
Old Jul 16, 2010 | 05:09 PM
G35Robby's Avatar
Y Im getting an OEM diff but chaning a few internals out for track use.
But the plan is to get a used oem lsd diff because i found one for 350 bucks.
Old Jul 16, 2010 | 05:48 PM
LightsOut's Avatar
SIETESG
just a suggestion...
Old Jul 16, 2010 | 06:02 PM
G35Robby's Avatar
Can you post the link?
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
doakley92
Sep 25, 2015 12:58 PM
