G was running high on RPM?
Old Aug 24, 2010 | 10:43 PM
jelloman's Avatar
So I was driving home from work today, while on the freeway, I could hear the car was running louder than usual. I looked around, the RPM was at 3.3K while going 60mph,and at 3.5K @ 65 mph. I made sure that I was in 5th(AT), and I was. I started to think is that normal? Or am I just over-thinking cause I was driving a 2010 G loaner with 7 speed the week before which the rpm are usually lower....
I took the exit and came to a stop light, the car was idling at about 1.8K and I knew something was wrong. I turned the car off and turn it back on really quick, nothing changed. It was 97 degree out and I remember reading something about idling issue with the G when it's hot out.
Came home, pulled into the garage, turned the car off, and the needle was stuck at 1K!!!!
I waited for a couple mins before turning it on again and it finally stays at about 700 rpm idling.
What is the problem? the heat? I just did the throttle sensitivity TSB last week, does it has anything to do with it? Anyone has previous experience? My wife usually drives the G, so I want to make sure she will be okay driving it everyday. Thank you in advance.
Old Aug 24, 2010 | 11:30 PM
bigc's Avatar
Wings Nation
yeah, those cruising RPMs are much higher than normal
Old Aug 25, 2010 | 02:59 PM
Q8y_drifter's Avatar
I've heard this issue a couple times before. If it's idling high you may have a vacuum leak.
Old Aug 25, 2010 | 03:06 PM
jelloman's Avatar
oh.. so bring back to the dealer? or is there anything I can do to fix it? or just wait out?
Old Aug 25, 2010 | 10:01 PM
Rollo's Avatar
I suspect that is a guage error since it was on 1k while turned off. I would talk to the dealer about it...show them that picture.
Old Aug 31, 2010 | 05:35 PM
IvoryPearl07G's Avatar
sounds like the needle is grabbing the gauge face....but you said the car sounds louder. as in more rpms. so that leans back towards an engine or tansmission issue.
personally to me it sounds like your riding in fourth gear.
G35VSHNG37
Oct 25, 2015 08:43 PM
03sedang35
Aug 29, 2015 07:56 PM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
