fluid change
Old Sep 30, 2010 | 12:06 AM
freakta's Avatar
fluid change
im wondering how often you need to change the auto tranny fluid, tranfer case fluid, and rear diff fluid?
Old Sep 30, 2010 | 06:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
I change mine every 30K miles but for official intervals check the owner's manual.
Old Sep 30, 2010 | 06:05 AM
djw88's Avatar
me too 30k
+1
Old Sep 30, 2010 | 09:35 AM
dohturdima's Avatar
Tranny: drain and fill at 30K, complete flush at 60K
Rear diff and transfer case: 60K
Old Sep 30, 2010 | 10:16 AM
Austin713's Avatar
^^ what he said... dont forget the Coolant at 60k and the power steering fluid
Old Oct 13, 2010 | 10:08 AM
freakta's Avatar
im going to change my diffs this weekend, and the tranny and transfer case next weekend. im lokng to use redline synth all the way around. but cant find wich weight to use or if i can/should put anything in for the diffs or clutched in the tranny. any suggestions would be appreciated
Old Oct 13, 2010 | 10:54 AM
E-Ticket Ride's Avatar
One member used Amsoil with unfavorable results. You may want to use Nissan fluid instead
Old Oct 13, 2010 | 02:36 PM
kool_yaar's Avatar
^+1 the member complained about the car not shifting correctly and not holding RPMs correctly, could void warranty as well!
Old Oct 15, 2010 | 09:08 AM
freakta's Avatar
that sounds odd. the only transmissions ive ever had that needed a specific fluid were the honda ones because they use some crazy honda only fluid.
Old Oct 15, 2010 | 10:27 PM
mifesto's Avatar
bought my car at 40k miles and barely drive 5k a year (and driven like a baby). at 52k miles tonight i checked dipstick and fluid color looked light brown-red(kinda like clean engine oil). it was also overfilled abit. judging by slight overfill and relatively light color; previous owner may have drained and filled once in past.
im gonna do drain and fill this weekend with maticJ, then another drain and fill following and report in... been reading and it seems even easier then regular MT tranny fluid change, not worried.
Old Oct 15, 2010 | 10:36 PM
thescreensavers's Avatar
Mr.202?
^ No such thing as Matic-J any more, Matic-S is the replacement and its semi synthetic.
Old Oct 15, 2010 | 10:57 PM
mifesto's Avatar
yeah i forgot it was one of those matic J or S... i also have two quarts of matic D's ready for the t-case but i think i can hold off on that abit since one drain/fill completes it.
what sucks is dip stick level is slightly over hot max level although its been sitting for 24 hours; think im gonna get abit more then typical drain amount the first time...
Old Oct 17, 2010 | 09:02 AM
slimjim2525's Avatar
I am going to hit 60k this week. Would you guys do a trany drain and fill or a flush? How about a tranny shop do it rather than a nissan dealer? I hate stealers.
Old Oct 18, 2010 | 08:56 AM
freakta's Avatar
so i didnt have time this weekend but i bought redline for the diffs, and am a bit unsure what the t case needs?
Old Oct 22, 2010 | 01:19 PM
Matchstickman60's Avatar
How many quarts of transmission oil is require to fill the tranny because i am also thinking about changing the fluids over the weekend
