My serpentine belt squeals like a mofo...
Old Nov 7, 2010 | 01:18 AM
G35_916's Avatar
My serpentine belt squeals like a ****...
as some of you know, my car is salvage with about 39k on it. When I bought the car, the guy said the car sometimes squeals when the AC is kicked on. I never had any issues for about 2 months even with the AC on. Recently, the car will squeal when first on and even when warmed up. AC on or off doesn't matter. I applied some belt coditioner to prevent squealing and the car started to squeal like crazy, but after driving for a while it did calm down, but it still does squeal.
The belt seems fine. No pulley seems bent or wobbly. So what gives? I was thinking about changing the belt. Does anybody have a DIY for the belt?
Old Nov 7, 2010 | 01:21 AM
mathnerd88's Avatar
I had the dealer replace my serpentine belt under warranty around 40k miles because it started squeaking. The dealer said that my tensioner was bad and caused the belt to shred. The squealing noise means that your belt is going bad. Get it checked and replaced.
Old Nov 7, 2010 | 01:22 AM
TIAN's Avatar
Hold The Line
I changed both to gatorbacks and one of those two squeal on a cold start for about 10 secs. Don't know if its cause its too tight or too loose. I can't tell cause I can't lift or find anyone to lift my car
Buddy recommended and insisted that I spray some type of belt grease.
Old Nov 7, 2010 | 03:09 AM
G35_916's Avatar
So I found this DIY...its from a 350z, but same system as ours. Basically for any VQ35HR engines. I need to purchase a 1/2 inch breaker bar.
http://my350z.com/forum/vq35hr/43285...t-for-hrs.html
Old Nov 7, 2010 | 04:29 AM
Project's Avatar
Its easy takes about 15 mins. Get under there loose the tensioner and replace both belts at same time.
Old Nov 7, 2010 | 01:01 PM
kool_yaar's Avatar
its even easier 07+, theres only one belt and the tensioner is auto.
Old Nov 7, 2010 | 01:53 PM
G35_916's Avatar
So my brother is bringing over the half inch breaker bar, but I just noticed that my car is missing the plastic cover that goes right under and behind the bumper, Which prevents stuff from splashing up. That may be the problem. Anybody know where I can pick one up other than the stealer, the part number?
Old Nov 7, 2010 | 02:16 PM
Project's Avatar
Cheaper online. Or you can get a aluminum one that looks nicer if you have some money laying around.
Heres a link to plastic for 07-08 dont know what year you have
http://www.autopartswarehouse.com/de...e&apwid39Jxwtd
Old Nov 7, 2010 | 10:29 PM
G35_916's Avatar
Project,
The one you listed is for the awd models. I guess its different for a awd vs not.
Old Nov 8, 2010 | 12:20 AM
kool_yaar's Avatar
^ yes they are different, im pretty sure you can get it from everythingg35.com or rick@riverside for sure!
Old Nov 8, 2010 | 12:49 AM
G35_916's Avatar
the first link did not have any...only mud guards.
I'll give rick a call, found the number online. Let's see what price he can get me.
Old Nov 8, 2010 | 12:55 AM
G35_916's Avatar
So changed the belt out. I used a serpentine belt tool from Kragen auto parts because my brother forgot to bring the breaker bar and the breaker bar at kragen was pretty thick so I went with the serpentine tool which worked like a charm. Probably didn't even need to change the belt because it looked to be in perfect shape and I bet the problem the whole time was the engine splash guard. Will order that as well in a couple days once I located the lowest price.
Old Nov 8, 2010 | 02:10 AM
bigc's Avatar
Wings Nation
a missing splash guard / undertray won't cause prolonged belt squeal.
Old Nov 8, 2010 | 05:27 PM
G35_916's Avatar
I guess that's good to hear because I felt like I changed it for no reason afte the fact. Why would you say that it wouldn't make a difference though...I would think water, debris shooting up in that area would cause squealing. The old belt looked to be in near perfect condition.
Old Nov 8, 2010 | 05:37 PM
AesonVirus's Avatar
Kool... you did your own?
Is it as easy as the write states? I thought about doing mine (it's due) but once I got a good look at it, I was concerned about being able to get my big hands down in to every pulley position. I'd hate to pull the belt and not be able to put the new one on.
The dealer wants $185 for the install. I'd love to do it myself it it's this easy.
What did you remove to have plenty of room to move about?
