Question about changing transmission fluid
My manual does not show capacities for ATF.
FSM does show 10.3 liter (10-7/8 US qt, 9-1/8 Imp qt) (reference value, use fluid level gauge to get closer estimates.)
I know ATF fluid change should be fairly easy, but am i the only one concerned about all the stuff the FSM recommends doing? Specifically, the need to use CONSULT to check proper temperatures before taking a reading from the fluid gauge?
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
But, if I wanted to do it manually, I would probably drain some ATF fluid, and measure how much was removed, via a cheap plastic container and masking tape, and then fill the new ATF to that same mark and pour it back in.
You could even wait for it to come to room temperature before marking to get the temperature the same as the replacement fluid.
soundmike, I wouldn't worry too much about the checking the fluid gauge after the proper temperature. If you are replacing exactly how much is coming out then why would your fluid gauge be off due to temperature?
As far as taking your car to be flushed by a "mechanic", I don't think any mechanic would be following FSM or using CONSULT unless they worked at a dealer. So how different would it be in doing it yourself? Also, 5 out of 10 people I talk to in regards to power flushes have had major headaches afterwards.
Otherwise, they hook a machine up to your transmission, and run your car. The pressures your car normally generates pushes the old ATF into the machine, and the machine pushes in new fluid. So you're getting almost all of the old stuff out, versus continuously diluting the bad stuff.
I guess it would be comparable to saying you're only going to drain 2 quarts of oil, put two quarts back in, and then a month later, doing that again and thinking it's equivalent to draining it all and refilling it.
Yeah, it's better than nothing, but not equivalent to a full flush.
PS - here's a link to a vendor selling an ATF flushing machine, and a description:
http://www.transaction25.com/html/our_product.html
FWIW, my car was machine flushed early in its life. No problems at all.
If its about 10 qts in there and i get 4-5 in a drain. Ill be happy and just do that for the time being.
EVO? WTF...
new auto evos using that SSD or w/e they call it are glass trans that you MUST use their fluids or it will break. So if he put anything other then OEM it the reason why its dead.
I've done drain and fills on all my cars. No issues. I've switched it up to using universals now. rather then OEM stuff, I have redline D4 in the T-case. M1 for the front/rear diffs. I used J-matic in the AT, i bought 12 used 4-5. I'm looking to unload it and go over to Amsoil or MAXLIFE. But if i cant unload it then i'll just use it.
Drain and fill is the way to go in almost all cases. Cheaper to do at home. No risk of something running dry with force pumps.
Is there a reason we can't use synthetic tranny fluid like Redline or Amsoil? thx
I did the second drain/refill after a week (about 400 miles). If you do this every 20-30k miles, two d/f's should be sufficient to keep the fluid fresh.
p.s. I drained a little over 5 qts on mine, with the front elevated about 6 inches. You can refer to my DIY here -- http://gshack.org/?p=276
#30
