Those with GTM RTP . . need lil help plz !
Old Oct 5, 2011 | 04:37 AM
Glover997's Avatar
Hi amigoz
ummm .. i'm lookin into these but i'm not in a position to understand what i have pointed out in red circles as shown in pic below
Also i've noticed these are built with two hangers as well . . Now where exactly these are supposed to settle ?
Finally . . i understood that gaskets are not included with this setup . . ok does it come with all necessary bolts at least ?!
thx in advance
first one replys i'll give him a thanx
Old Oct 6, 2011 | 04:18 PM
Glover997's Avatar
whats wrong guys . . two days with no response
ok i'll make it easier for u, forget about the hangers n jst answer on the other stuff.
i'll appreciate ur help..
thank you..
Old Oct 6, 2011 | 04:24 PM
E-Ticket Ride's Avatar
To my untrained eye, they look to be a wide band O2 bung.
Old Oct 6, 2011 | 04:34 PM
Glover997's Avatar
^ no they are not !
O2 ports are the other little welded pipes just near those holes i pointed out in red circles.
in fact . . i haven't seen those stuff in any test pipes nor HFCs ! put that hangers in record too !
Old Oct 6, 2011 | 04:58 PM
Not an O2 sensor, a separate wideband sensor bung for tuning
Something like this:
Old Oct 6, 2011 | 05:20 PM
Glover997's Avatar
now that explains
so they're jst optional from what i understood, no need to connect them or what so ever . .
ok how about those hangers . . thing is,i really don't like to fix and tight ma pipes in ma car with these, cuz TPs and HFCs are somehow supposed to be a lil flexible when installed, and these hangers won't help on this matter . . i saw someone who has broken his pipes when he took a piece off right on the hanged point while running over a small rock or somethin . . SO, do i really have to install my GTM RTP using these hangers ?!!
Old Oct 7, 2011 | 03:05 PM
Defratos's Avatar
You're Despicable
well I dunno what those things are for either so I wouldn't have been of much help,
on a good note my pipes arrived Thursday and hopefully gonna get them installed tom, all wrapped up and ready to go:
Old Oct 7, 2011 | 03:21 PM
See the nut that Maz has screwed into the hole, that's a sure sign it's for the wideband sensor.
If the sensor's used, it's inserted there. If it isn't used, those nuts are used to plug the hole.
Old Oct 7, 2011 | 03:29 PM
TomPeters's Avatar
^ Those pipes look beautiful! Looks like you got the non-resonated ones.
Glover - Why so many questions about these when you already have ART's???
I'd suggest that anyone who didn't receive any gaskets with their pipes purchase the Berk gaskets.... they're call the collector gaskets for the end that butts up to the manifolds. They also sell specific gaskets for the other end, Temp 2 gaskets.
Old Oct 7, 2011 | 06:08 PM
Glover997's Avatar
@ Defratos . . Congrats man, they do look sick with the wrap
did they come with all necessary screws n bolts ?! i know they must of been included but i just wanna make sure since gaskets are not included
Old Oct 7, 2011 | 06:51 PM
Glover997's Avatar
mmm .. i'm not sure if u've read my story when i got my arts installed by a shop which i'm sure used to sell vegetables in the past ! FAIL !!
anyways after i solved the O2 sensor problem, another problem came up . . a damn leakage that i cudn't control between the pipes flang . . So here i decided to start over and get new pipes.
You probably wud ask me why not re-install my current pipes and maybe get new gaskets, bolts..etc but i'm really fed up guys, thats it . .i wanna start over n get new ones. it's just i dunno.. my car doesn't feel alright since i've installed these
So yea .. time to take them off and ease up this headache !
I'm 99% pulling trigger on GTM RTP.
Old Oct 8, 2011 | 03:24 AM
Defratos's Avatar
You're Despicable
Thanks bro, um 10 bolts came with it, but there were not bracing bolts included. Of course if you already had bracing bolts on your original pipes then you can take those and just use them instead, that's what I did.
Now I'm a little worried hearing how you've had problem with you pipes, they were ART pipes correct? Good luck with it and I'll let you guys know how mine goes along as I'll be trying to install everything today (if I'm lucky)
Old Oct 8, 2011 | 07:50 AM
Defratos's Avatar
You're Despicable
I'm surprised, I know you had problems with your ART pipes but are they really that much of a hassle that you'd rather just change to GTM test pipes?
Old Oct 8, 2011 | 06:41 PM
Glover997's Avatar
Yes they are !
but like i said before .. all problems i had with these is only because of the bad installation from the beginning, so it doesn't have to do anything with the ART pipes themselves.
You just don't have to worry about yours as long as u perform the installation by a trusted shop, thats all i can say.
one more thing . .what is a bracing bolt ?
Old Oct 9, 2011 | 01:41 AM
Defratos's Avatar
You're Despicable
The bracing bolts are the two bolts that are already attached to the Pipes in the pic above. It basically holds the test pipes to a metal plate on the car to keep everything from moving about too much.
I actually have to install those bolts later on today as I had taken out my original exhaust brace that these fit onto.
On a good note I just drove into work and no engine lights or anything soooo, so far so good.
