Hesitation/Bog/Sputter @ 3k RPM
Old Oct 17, 2011 | 11:05 PM
OMG35S's Avatar
Question Hesitation/Bog/Sputter @ 3k RPM
I did a mountain run with a few of my friends the other day and noticed some bog/sputter/hesitation at around 2k-3k RPM.
Happens in almost every gear, when you heavy accelerate at low RPM. Once you pass 3k RPM there is no sputter/bog/sputter. It feels good till around 2.5k RPM and then it hiccups/sputters/bogs/hesitates for a split-second and once it passes 3k RPM it picks up again.
Yes, I do have RTP's installed as well as a full exhaust and I've done my research. It seems like there are others with similar issues who have aftermarket cats/pipes. Some say a tune fixes it and others have gotten the tune and still have the issue!?
I have Stillen V3 CAI's in my basement and I'm thinking about installing them and maybe it won't hesitate/sputter/bog anymore. Honestly, it's not bad if you are daily driving but on the mountain it was more obvious. Car felt great by the way!
Anyone have a concrete reason why this happens? I'm assuming it's going from lean to rich real quick and the ECU hiccups? Will the intake even it out? I'm not planning on getting a tune till next year...
Thanks!
Old Oct 18, 2011 | 04:36 AM
harp00n's Avatar
maybe at 3750rpm? it could be torque converter locking/unlocking
Old Oct 22, 2011 | 05:00 PM
Q8y_drifter's Avatar
My guess is damaged O2 sensors (the ones at the headers).
Old Dec 28, 2012 | 03:18 PM
Unbootable's Avatar
Hey OP,
Have you ever figured it out ???, I have the same problem !!!
Thanks,
Old Dec 29, 2012 | 02:42 PM
OMG35S's Avatar
Yeah, figured it out after a lot of research and updates.
Infiniti came out with a new ECU update. I don't know the TSB # off the top of my head but you should be able to find it. I went to Infiniti when I was still under warranty and requested they perform the TSB ECU update and it fixed my hesitation. Supposedly, the hesitation is there stock but it's more pronounced when you free up the exhaust.
Old Dec 29, 2012 | 04:52 PM
Unbootable's Avatar
Will give it a shot, Hopefully it works.
Many thanks,
Old Feb 13, 2026 | 07:32 PM
conley17's Avatar
hey same problem please help
Hey i’m having the same problem after installing isr high flow cats do you know how to fix it?
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alessandro
Oct 8, 2015 09:29 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
