Gaskets for Exhaust
Old Apr 15, 2012 | 11:15 AM
Defratos's Avatar
You're Despicable
Question Gaskets for Exhaust
Recently I've been getting a weird metal rattling sound at around 3k rpm, the exhaust seems fine and everything seems solid, but I figured since I've had the exhaust for nearly 2 years (maybe longer can't remember) it's probably about time to change all the gaskets.
I've tried to search Invidia's website but I can't seem to access it, I wanted to know does anyone sell a replacement gasket kit for the Invidia Gemini?
or does anyone know where I can buy some good quality exhausts from other suppliers? I'm guessing any 60mm dia gaskets would do correct?
Old Apr 15, 2012 | 12:45 PM
Defratos's Avatar
You're Despicable
Actually does anyone know what the OEM exhaust diameter is?
Old Apr 15, 2012 | 03:36 PM
g35pillow's Avatar
Oem diameter is 2.5" I believe
Old Apr 15, 2012 | 04:57 PM
Defratos's Avatar
You're Despicable
2.5" = 63.5mm.....can we consider that the oem gaskets should be ok on my exhaust?
Old Apr 17, 2012 | 04:48 AM
Defratos's Avatar
You're Despicable
Bump* any advice?
Old Apr 19, 2012 | 08:05 AM
Defratos's Avatar
You're Despicable
Double Bump....
Can anyone shed some light if I can simply replace my Invidia gaskets with the OEM gaskets?
Invidia Dia = 60mm
OEM Dia = 63.5mm
Old Apr 27, 2012 | 02:58 PM
Glover997's Avatar
Which gaskets u need exactly ?! FYI .. No OEM gaskets are installed between the cats/headers manifolds ( those with 3bolts i mean ). as for the catback .. yes the factory do use them in between ( those with 2 bolts ). if u're referring to the catback gaskets then you can use a tube of a High Temp Red RTV silicone without gaskets with no issues or what so ever.
Old Apr 27, 2012 | 03:48 PM
Defratos's Avatar
You're Despicable
Yes the main gaskets I want to change are for the cat-back system, I would prefer to use gaskets instead of the High Temp Red RTV Silicone, because that would involve having to dismantle the exhaust and I don't have any places to do that.
With gaskets I'd be able to easily take out the old ones and replace them with the new ones.
The question is can I use the OEM gaskets on my Invidia Exhaust?
Old Apr 27, 2012 | 03:56 PM
Glover997's Avatar
^ yes you can use them. flanges are always identical to OEM spec no matter what size your after market pipes are.
Old Jun 28, 2013 | 05:41 PM
jconn02's Avatar
^^^ wrong... one of my gaskets fried itself to **** and when i went to autozone, pepboys etc.. they did not carry the right size gasket. the oem gasket is slightly bigger. ive been looking around as well and havent been able to find anything. hence how i came up on this old *** thread lol
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
