Custom Exhaust
Old Sep 8, 2012 | 03:25 PM
bat6wc's Avatar
Infiniti engineers could easily have developed different parts or a true dual system without it being loud. They chose this set up for a reason. There is also a reason why all these aftermarket catbacks yield maybe 2hp at the most. The cats are the most restrictive part.
and if they dont care about performance, why offer a 6spd MT or even an engine at over 300hp?
Old Sep 8, 2012 | 10:23 PM
mishmosh's Avatar
Where do you get 2hp? Most cat-backs are 8-12hp range. That is significant. None of them are quiet. When it comes to exhausts, you have to sacrifice noise to get the most power. A lot of noise is acceptable for the GTR but not for Infiniti sedans.
Why didn't Infiniti go with a long-tube intake setup if they wanted performance? Both Injen and Stillen G3 make more hp than stock. But why ask why? It is what it is.
Old Sep 8, 2012 | 10:57 PM
bat6wc's Avatar
No way 8-12hp and no way significant. And long tube intakes are not that beneficial either. Gains a few HP at high rpms. Been down the intake and exhaust road too many times. These are purely cosmetic mods.
Old Sep 29, 2012 | 12:58 PM
Shrt Bus's Avatar
Exactly! The 'real' gains are from a good tune or adding a power adder..
Rick
Old Sep 30, 2012 | 09:12 PM
mishmosh's Avatar
Rick
Most tunes I see are getting 8-10hp. Is that what you are calling "real"?
Old Sep 30, 2012 | 10:54 PM
blnewt's Avatar
I think it says quite a bit about how Infiniti engineered the Gs. Most aftermarket parts that can yield significant gains in other makes are quite minimal w/ the VQs, seems like they're pretty "maxed-out" from the factory, not a bad thing IMO.
Old Oct 2, 2012 | 10:48 AM
Shrt Bus's Avatar
if your talking about PEAK its ok.. its all about whats under the curve. The graphs that I have see have gained considerably under the curve..
Rick
Old Oct 26, 2012 | 02:54 PM
alicious's Avatar
Getting back to the topic, is there an update on this?
I just did the muffler delete, pipes striaght back to tips and it sounds great aside from the cabin drone between 1700-2500RPM like another person pointed out. Driving me nuts and i'm probably going to put the stock system back on.
Old Dec 11, 2012 | 06:23 PM
TaBzRx's Avatar
I did the muffler delete about 6 months ago and had the same problem with the cabin drone. Here is what I did to completely remove the drone:
https://g35driver.com/forums/v36-eng...esonators.html
Old Dec 18, 2012 | 06:53 PM
josephjochoa's Avatar
I deleted stock resonators and replaced with magnaflow 11835 resonated X. Dual all the way back with 0 drone and 0 rasp. Very small sound increase. Maybe not enough. Stock mufflers dampen sound a lot.
Old Jan 11, 2013 | 05:20 PM
alicious's Avatar
Got it. Much appreciated.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
