Low RPM trans slipping?
Old Jun 27, 2013 | 04:14 PM
MikeJones916's Avatar
Originally Posted by yosip1115
I have reason to believe your problem is different. The fact that when my AWD fuse is pulled the issue goes away leads me to believe the transfer case is the culprit. my symptoms are EXACTLY as he describes. I have left my fuse pulled and am running in RWD until this issue is resolved; if they sell the appropriate parts to fix it. If not, 6MT here we go. Do you have AWD? (On my iphone sorry)
I read somewhere that the issue is caused from the "electronically controlled coupler" in the T case assembly. Pulling the fuse cuts power to this coupler and will render the car RWD but there will be no shuddering under hard acceleration, low speed tight cornering, or part throttle low gear take offs. Someone with hands on experience with the AWD system chime in.
https://g35driver.com/forums/v36-eng...d-no-joke.html
Old Jun 27, 2013 | 04:22 PM
yosip1115's Avatar
Originally Posted by MikeJones916
Yes that is what I did but why did you send me this link lol. I am wondering specifically if you can replace just the one part in the t case to fix the issue this thread is about.
Old Jun 27, 2013 | 10:52 PM
I saw a lot of conversation in that thread, thought maybe some of the information you needed might be in there.
Old Jun 28, 2013 | 03:29 PM
yosip1115's Avatar
Thank you for the info, he refers to it as a front clutch solenoid in the link you sent me. Regardless, I have to find a schematic and a part # to see if it can be replaced separately. The t case is about 450 shipped (used) which is not so bad for a guaranteed easy fix.
Last edited by yosip1115; Jun 28, 2013 at 03:31 PM. Reason: I'm a careless bastard
Old Jul 10, 2013 | 01:37 PM
chris_sims1981's Avatar
I just noticed a slight hesitation on my 07 X sedan when leaving from a standstil
l at around 2500 rpm
Old Jul 10, 2013 | 01:41 PM
yosip1115's Avatar
Check your MAF sensor, I mean clean it with MAF sensor cleaner, unplugged; after you unplug the battery. Press the brake pedal for 10 seconds when you have the battery disconnected too.
Old Jul 10, 2013 | 07:57 PM
Ok thanks man, will do so asap
Old Jul 10, 2013 | 08:35 PM
vqsmile's Avatar
^^ FYI, he's got a 1st gen, and you've got a 2nd gen, so you've got two MAFs to clean, not one.
Old Jul 10, 2013 | 08:44 PM
Yeah I'm aware of that but thanks anyhow
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
Jnm07
Sep 5, 2015 01:16 AM
