Engine making a knocking sound
Old Mar 7, 2014 | 10:22 AM
DFWG35driver's Avatar
Hey I was wondering if any of you guys knew what this sound might be? It sounds like lifters knocking but I don't think that's it. It only makes the sound after the rev drop under 2k rpm and as it drops from higher revs and idle. I've run synthetic in her since I bought her at 41k and she has 125k now. Last oil change I ran a can of chemtool through the crank and run her for 200 miles then changed the oil again with a 40 weight. Still the same, no change at all. So I changed the oil to a 5 weight to see if the lower viscosity would "degunk" whatever was the cause, still no change. I asked a mechanic friend of mine and he said it sounded like it was coming from the bottom end of the motor. Any ideas would be helpful please.
Thanks!
Old Mar 7, 2014 | 10:24 AM
Oh and it does it hot or cold, louder when cold but the frequency is the same. I've also noticed very little power drop off. She runs great I'm just worried.
Old Jul 27, 2015 | 10:04 PM
V36driver's Avatar
Same hear when the rev drops around 2k there's a rattle noise coming from under the engine
Old Jul 28, 2015 | 08:19 AM
WhosUrBuddiee's Avatar
Maybe it is .... knocked up.
Old Jul 28, 2015 | 08:26 AM
Mr. Brooks's Avatar
Thumbs up
If it's knocked up, you might be getting a little baby G. My question is, who's the daddy.
Old Jul 28, 2015 | 08:35 AM
DigitalDeviant's Avatar
Rods knock. Lifters tick. As you haven't supplied an audio sample its hard to determine. Search YouTube for rod knock / lifter tick and you'll hear the difference.
TWASkyliner
Feb 8, 2020 08:00 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
rping
Jul 26, 2015 09:53 PM
cyrus32
Jul 18, 2015 06:22 PM
Thaaa_king
Jul 18, 2015 05:56 PM
