DIY Mass Airflow Sensor Cleaning MAF
Old Sep 16, 2014 | 04:26 PM
beto4632's Avatar
This is a DIY on how to clean out a dirty MAF, I was experiencing some bad hesitation and throttle response. And this definitely help out a lot. And this should also be a regular thing to do every 10k or so. Lets get started..
First you will need a Can of CRC Mass Air Flow Cleaner.
Locate your MAF
Remove the 2 Small philips heads
Pull out slowly and it should look like this, and there is a tab you will have to separate it form.
Once removed BE VERY CAREFUL DONT TOUCH the little parts inside the MAF if these get damaged you will need to replace the Sensor this is were you will use your can of CRC MAF Cleaner I shot it about 8 times.
Once done with both of them let dry for 10-20 min then reinstall, and your done
Old Sep 29, 2014 | 12:57 AM
Jeremy1607's Avatar
Good DIY ! Did you get any problems after installing them back on the car ? Like high idle, check engine light, shudder or things like that ?
Old Sep 29, 2014 | 09:10 PM
beto4632's Avatar
No problems what so ever, it actually solved problems i was having rough shifts at 2 and 3 and it fixed it while it also is giving me better MPG readings and my MPG went up form 18 to 20 on a G35X
Old Sep 30, 2014 | 02:15 AM
takeapieandrun's Avatar
Fixed your 2 to 3 shifts you say? Hmm I really gotta do this one of these weekends.
junon
Jan 14, 2023 09:37 PM
esotericrider
Feb 14, 2022 07:19 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
newg37
Jul 26, 2015 09:32 AM
