PO420 error after accident?
Old Sep 8, 2018 | 05:23 PM
cleverclaire's Avatar
hello all
Unfortunately, I was rear-ended a couple of weeks ago. Yesterday my Service Engine Light came in and I checked the code to find the PO420 Catalytic System below threshold bank 1.
Any my chance this is related to the damage in the rear? Or unrelated O2 sensor or Catalytic Converter problem??
Thanks.
Old Sep 8, 2018 | 05:47 PM
telcoman's Avatar
Veteran: Army
Assuming the other driver that hit you in the rear will be judged at fault, you should be able to have everything covered.by your insurance company
Telcoman
Old Sep 8, 2018 | 10:19 PM
Telcoman
could an accident like this impact the Catalyst system?
Old Sep 9, 2018 | 05:35 AM
telcoman's Avatar
Veteran: Army
Most probably?
Have you or a body shop carefully inspected the underside of your vehicle on a lift after the accident?
Telcoman
Old Sep 10, 2018 | 08:04 AM
Most probably?
Telcoman
We have not looked under the car yet. If there is damage from the accident, it is likely at the very rear end of the system. Perhaps that could trigger an issue?
I suppose the exhaust could be damaged in a way that causes an obstruction?
Old Sep 10, 2018 | 09:15 PM
neal.a.nelson's Avatar
You are not clever at all if you don't get the car inspected by a competent body shop right now. The tailpipe is connected to the engine, so the accident could definitely affect any part in between. You wanted advice, heed it.
Old Sep 14, 2018 | 02:31 PM
I appreciate your friendly advice. I took the vehicle to 4 bodyshops for estimates and none put the car on a lift. I have never seen one do that during an estimate, but I have never had much damage to a vehicle either.
The SEL light had not come on when I was getting the estimates so there was no discussion of that.
As of now the light has gone out and not returned so I’m not sure what the issue is but I will mention it when I take the car in for repairs next week.
Old Sep 14, 2018 | 03:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just make sure to tell them to inspect the exhaust system as well. It could be entirely unrelated or it could be a broken weld on the pipe somewhere.
nineiron
Mar 6, 2015 11:27 AM
GNN60GT500
Feb 5, 2012 10:11 AM
gabe3d
Jan 6, 2005 06:20 PM
g35chic
West
88
Nov 20, 2003 09:30 PM
