V36 U1000 Code?
Old Apr 12, 2023 | 07:47 PM
Xotro's Avatar
2007 G35X with Premium Bose Sound
V36 U1000 Code?
I have a 2007 G35X with a U1000 code, my 1st 2nd and 3rd gear all shift weird, but the rest are fine. I’ll attach an image of what the code says, any possible fixes would be greatly appreciated, as I don’t want to ruin my transmission.
Old Apr 15, 2023 | 12:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
U1000 means one of the computers is malfunctioning, there's 7-8 different computers, any of them could cause that code.
Since you're having transmission shift problems it's probably the TCM. Start by cleaning the TCM ground wire. On your timing chain cover in the middle, at the top, you should see two wires grounded out on two green bolts. Unbolt, wire brush, apply electrical anti-oxidation grease, bolt them back on, see if it fixes the problem.
Old Apr 16, 2023 | 04:58 PM
Xotro's Avatar
Is this the ground you’re taking about? Or is it a different one further down?
Old Dec 21, 2023 | 07:21 AM
oro mero's Avatar
g35 sedan rwd sport package
Was this issue ever fixed ? I’m in same boat but mine won’t shift past 3rd and no gear indicator on cluster.
Jum
SFL G CLUB
Dec 6, 2008 12:21 PM
