How to change interior light bulbs in doors?
Old May 3, 2007 | 06:44 PM
  #46
kmuniz78's Avatar
I also ordered the 6k Authentic Philips Ultinon 6000K D2S Bulbs from Autoluminate on eBay ($203.99; expensive, but who cares). Should be here any day now.
For the LED's (eBay - Lot of 10 194/168/158 White High-Power LED Lights Bulbs - $38.98) or from http://www.hid-lights.com (click on miniature bulbs; you can use the last four in the first grouping of lights).
ordered them through
Old May 3, 2007 | 06:51 PM
  #47
kmuniz78's Avatar
P.S.: https://g35driver.com/forums/nationalgclub/121825-lots-leds-installed-pics.html
Old May 4, 2007 | 10:07 AM
  #48
dafinman's Avatar
Thanks for your posts. What temp are the OEM headlights?
Old May 4, 2007 | 10:29 AM
  #49
kmuniz78's Avatar
4300k (kelvin).
Old May 8, 2007 | 10:53 AM
  #50
dafinman's Avatar
Got the interior lights changed out but not sure how to get to the tag lights. Any trick to this?
BTW Kmuniz got yoour new headlights in yet? How do they look
Old May 8, 2007 | 12:28 PM
  #51
kmuniz78's Avatar
Still waiting. Placed the order 05/02. Hopefully will be in today. It said 2-5 days. Um, hello???? Hate waiting. : /
Old May 8, 2007 | 03:51 PM
  #52
Hokie_G's Avatar
Posted from another thread.
I just got my lights from the ebay guy yesterday. I was starting to worry a little bit but there the package was in the mailbox.
It took me about an hour to get 8 bulbs in. FWIW, the screwdriver I was using to remove the covers to maps light was too small. That plastic is very soft and I did leave a very slight indentation in the edge of the plastic. Yes I was using a towel like it's illustrated in the manaul. Again that plastic is very very soft even malleable to some extent.
Once I switched out to a wider and larger screwdriver I was able to pop the covers out relatively easily. I was thinking that smaller was better but not in this case.
Just be careful not to mar up the trim edge of the map lights.
Oh yeah, the LEDs look great. Very different glow to them and I think it complements the HIDs immensely.
-Frank
Old May 8, 2007 | 05:11 PM
  #53
dafinman's Avatar
Yeah and also the analog clock.
Still would like some guidance on getting to the Tag bulbs.
Old May 8, 2007 | 08:00 PM
  #54
bertmauricio's Avatar
There's a white plastic tab that you squeeze with your finger and the light assembly will drop down.
Old May 8, 2007 | 11:30 PM
  #55
daluder's Avatar
i ordered from the ebay guy two weeks ago and after 4 emails he said they are backordered. i waited one more week then cancelled after he wouldnt respond with an estimited timeframe. now i have to wait for paypal to pay me back. good luck getting your lights. i am wondering if the 10 dollor a piece lights are any cool. has ayone tried those yet?
Old May 16, 2007 | 04:19 PM
  #56
psymonG35's Avatar
I just ordered from SuperBrightLEDS
Yesterday Morning.
2 x WLED 4-LED bulb for Door
2 x WLED 4-LED bulb for License Plate
3 x WLED 6-LED bulb for Rear Reading Lights and Trunk
2 x WLED 5-LED Wide Angle LED bulb for Map Lights
They Shipped yesterday and I should have them by Friday! I will post Pictures of the compare - I am curious to see the difference between the 5 and 6 LED bulbs
Old May 17, 2007 | 04:22 AM
  #57
h2mann's Avatar
superbrightleds is the way to go. Got my order in a few days and had all of the lights swapped out in about 1 1/2 hours. Super easy and price was comparable to the ebay guy.
Old Jun 4, 2007 | 05:02 PM
  #58
dafinman's Avatar
Not the best thread to post this under but has anyone looked at some replacemeny bulbs for the front fog lights or clearance/marker lights?
Old Jun 6, 2007 | 02:43 AM
  #59
kenasaki's Avatar
guys, im still soo freakin confused about which bulbs to order.
i need another str8 breakdown of each bulb for the sedans.
the front 2 dome lights and front doors are festoons, right? what about the bulb for the rear passenger seats?
and i want to also replace the reverse bulbs to not leds, just something brighter and whiter than stock. can someone gimme info on that as well?
Old Jun 6, 2007 | 01:35 PM
  #60
psymonG35's Avatar
for the Sedan all the interior bulbs and the license plate are all wedge bulbs 194/168 type.
I have replaced the bulbs in 4 G35 Sedans - all of us at work really like the glow of the LED as opposed to the incandescent yellow.
Here is what I did to replace all of them for LED in my G - (the others went all white - I like the blue in the door)
2 x WLED 6-LED bulb for Door (Blue)
2 x WLED 4-LED bulb for License Plate (White)
3 x WLED 4-LED bulb for Rear Reading Lights (White)
2 x WLED 5-LED Wide Angle LED bulb for Map Lights and Trunk (White)
The reverse Lights I haven't done yet but if you look in your owner's manual it has the bulb type there
