flood
Old May 4, 2007 | 02:03 AM
salerngo45's Avatar
flood
anyone have any water leaks in the 07. mines flooded for the second time. first time i thoguht i lefta window open but i guess not infiniti wont fix it cause i have an amp in the car.
Old May 4, 2007 | 06:17 AM
empfl's Avatar
where are the leaks comin from?? never heard that b4.. gl w/ the fix
Old May 4, 2007 | 07:40 AM
Garnet Canuck's Avatar
Traveling Administrator
Nope, not an issue here at all. Where is the water coming in at? And what does an amp in your car have to do with a water leak? It seems like we are missing part of the story here or something.
Old May 4, 2007 | 04:50 PM
razo168's Avatar
i had a flood as well.. it was due to my 0 gauge power wire from the battery to the amp in the trunk..
check how that wire is ran.. if it moves rubber circular plastic pieces.. then its wrong.. try pouring a cup of water into where that wire runs.. to see what hapepens.. this is what happened.. i rerouted to run the power wire near passenger door..
at first i had it driver side..
hope this helps..
no flood since..
esotericrider
Jul 27, 2015 10:18 PM
Omar
Jan 13, 2005 12:10 PM
cbr600rr
West
30
Jan 29, 2004 02:34 AM
cbr600rr
Dec 19, 2003 11:07 AM
