10" sevas +40 offser...anyone running them??
Old Jun 1, 2007 | 05:49 PM
g35_6gear's Avatar
Is anyone running a Sevas 10" wide rear rim with the +40 offset on their 07 G sedan?? Any issues?? Looking at 20x10 rear.
Old Jun 1, 2007 | 05:59 PM
g35_6gear's Avatar
Found my answer...not my style.
https://g35driver.com/forums/showthr...89#post1692089
Old Jun 1, 2007 | 06:00 PM
ttrank's Avatar
Grocery getter
I would look a lot better if you go lower and they come in.
Old Jun 1, 2007 | 11:37 PM
terrycs's Avatar
20 x 10 with +40mm offset has been done -
https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/159247-data-base-lowered-aftermarket-rims-tires.html
Keep in mind the tire will move in a little bit after the car is lowered. As far as I know, the one you saw was not lowered.
Old Jun 1, 2007 | 11:40 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you lower the car and run -1.8 camber or more then they'll fit. If it was me, i'd go with a +45 (obviously not Sevas).
-GP-
Old Jun 1, 2007 | 11:49 PM
terrycs's Avatar
-GP-
What are your thoughts about +48 or maybe +50 offsets for my car with the rear camber arms with alignment in spec?
Old Jun 1, 2007 | 11:53 PM
a +48 on a 10" rim would be perfect with a 275/30 tire, you could even get the alignment back within spec and not worry about getting too close to the fender. I only wish that i could have a +48 on mine. My next set of wheels will be a 20x9.5 in the rear with a +45 so i can run -1.0 camber, i cant go more than -1.6 as of now with the +40 on a 10"
-GP-
Old Jun 2, 2007 | 12:06 AM
terrycs's Avatar
-GP-
Do think I can stuff a 285? Have you ever seen or worked on one that wide?
Old Jun 2, 2007 | 12:07 AM
I havent seen a 285 on a 10" wheel just because no one has ordered custom wheels with a high enough offset, everyone has sevas with the +40. I'm sure you could stuff a 285/30 in there with the +48-50 offset. Are you looking at running 19's or 20's? I'll be putting a 285/30/20 on my 9.5 +45
-GP-
Old Jun 2, 2007 | 12:25 AM
terrycs's Avatar
-GP-
Def going with 20 x 10, hopefully with the 285, but I think the odds are against me. The hard part is the picking offset.
Since this has never been done to my knowledge and I'm asking for a "non-standard" offset, the wheel mfr does not want to assume the risk that it will not fit, so I can't have them make another set if they don't fit without paying for them.
Also, once the 285s are mounted, I can't return them if they don't fit either.
Plus I'm in the middle of fitting a Stop-Tech BBK in the car as well. The rotors are the same dia as the stock rear, except they will be thicker.
Old Jun 3, 2007 | 01:30 AM
perry05G35's Avatar
Terry you are doing big things way to go and good luck.
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
