Trying to find the fuse for instrument cluster?
Old Jun 8, 2007 | 12:32 PM
bruuster's Avatar
I'll post this here in the Tech section because no one was able to reply in the 2007 G35 sedan forum after a week. Hope one of you tech guys can help.
I've looked through the manual. And though most of my previous cars have a description key for each fuse ( example: 20A headlights and wipers), this manual only tells you where the fuses are located.
The inside cover of the fuse box only gives a general description. So does anyone know which fuse for the instrument cluster?(speedo and tach)
Also, the fuel pump?
I put in my own kill switch and use these contact points.
Thanks,
Bruce in L.A.
__________________
TheBay
Aug 27, 2015 05:08 AM
Danielek
Aug 11, 2015 09:33 AM
.cakestar
Aug 4, 2015 09:05 PM
.cakestar
Jul 28, 2015 01:57 PM
