Oil Change Alert
Old Jun 20, 2007 | 12:33 AM
Greenlantern84's Avatar
Exclamation Oil Change Alert
So friday the maintenance alert for the oil came on in the center dash and has been coming on every time i start my G. I barely got 2050k, so its too soon. might have to take the car to the dealer and smack'em around lol, anyone else have the same issue?
Old Jun 20, 2007 | 12:34 AM
krazzyguju's Avatar
is it pre-programmed to tell you when you have to change your oil? Or do you have to set that yourself under the Maintenace settings?
Old Jun 20, 2007 | 09:37 AM
kmuniz78's Avatar
Check under your Info button, then select maintenance. I believe your first oil change should be around the 3500-3700 mark.
Old Jun 20, 2007 | 10:37 AM
HungNg85's Avatar
Yes, this is just a user alert and you set it at any mileage you want to. I believe you hit the settings button to popup a lot of options on the screen, then select scheduled maintenance.
Old Jun 20, 2007 | 12:24 PM
theacolyte's Avatar
Spoon!
3750
Old Jun 20, 2007 | 04:00 PM
BlkG35Sport's Avatar
what is it for synthetic oil? Meaning how many miles?
Old Jul 3, 2007 | 07:37 AM
Virus's Avatar
The only way to know for sure would be to send it in to blackstone for oil analysis. It costs $20. From owning a Maxima however, I can tell you that Amsoil is generally good for up to 17k with a filter change halfway through or possibly twice. I went 10k with Amsoil. Mobil 1 EP will also be good for at least 10k with a filter change at 5k. I'm uncertain of other syns like Penzoil Platinum, Redline and the German Castrol Syntec. Stay away from Royal Purple. While it's a great racing oil, it's shown time and again it's not good for extended drain intervals past 5k.
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
